My personal Linux backup strategy
Yeah, tools in the ssh, scp, s* category definitely beat ancient technology like telnet and used correctly they are a useful alternative to NFS too.
Ugh - I deleted a lot of important files from my backup with the stupid use of an rsync option (–delete-excluded) I was thinking it would only delete what was on the excludes list. But no, it deletes everything that’s not in the source directory.
Fortunately, I had a backup of my backup, which saved the day.
“Fortunately, I had a backup of my backup, which saved the day.” That’s THE WAY to do it, and I practice what I preach. For me, most of my online content is where I find, and even document things, so I can re-create most of my systems simply by installing or reinstalling from USB removable drives. On the systems where I actually save more content, I back up that content periodically. Today, as a matter of fact, I restored a system that worked but was behaving in a funky way. The restore not only brought it to a current state, equivalent to what I replaced except it works cleanly; I’m using it now in fact.
Yes! Nowdays all modern Linux Distro are on nfs v4.
I still prefer using Samba for development purposes, where need to share folders between Linux and Windows. For what I’ve tried itt’s more compatible and consistent
Now I’m making backups of my backups of my backups. A cascade of backups, if you will, from my desktop, to the dedicated Debian 13 nfs server, to storage on 2 other Debian machines and a FreeBSD machine. Plenty of backups if anything ever goes wrong.
BTW I reconfigured my dedicated nfs server to serve nfsv4 only and specify v4 on my desktop, and a dbench test on the client showed a surprisingly big performance increase.
I have connected google drive using rclone. And I have a back up scrip running. Crontab ensures hourly back ups.
I also have a Sony HDD :pensive_face: as a hard back up.
It’s weird that Google doesn’t even offer a Linux client for google drive. Even my Yandex drive has an official Linux client.
Agreed! I used to use overGrive because it was a on time fee.
But now Gnome has built-in Google Drive sync, so I just use that:
Interesting. OverGrive mentions Debian, Ubuntu, Mint. I use MX KDE, so it should work.
Yes, I noticed that the website address has changed. Used to be under this domain:
Maybe they seperated, or sold it.
Could you explain? I thought we needed rclone to sync google drive .
Murphy’s Law says that the more thorough your backups, the less chance you will ever need to use them. :slight_smile:
Can you sync Google Drive with anything that works with their api/auth.
“Murphy was an ‘optimist’!” That’s what I HEARD anyway! :grinning_face:
Long story short, I (not very often) dd the whole hdd to have ‘drop-in’ bootable copy of my system. Since then I (more often) just rsync home directories.
In the end I disbandoned all the huge “strategy” and go on…
for my backups nowdays I’m using:
  • Timeshift as main Linux backup
  • Borg / Vorta for backking up some Linux sensitive folders and files
  • AOMEI licensed for backking up my Windows
Nothing more. I think btw it’s more the enough :slight_smile:
Timeshift is available on the distribution that I typically use; as I’ve said more than once, I adopt a somewhat different strategy, using a combination of Web-based information, system snapshots placed on external USB, system replication on multiple hardware platforms, and in this way, I have multiple backups and no one single point of failure. Unconventional without a doubt, but it’s worked for me for a surprisingly long period of time.
I posted earlier a little bit about how I do backups in another topic, but this topic is a better place and I think I can elaborate a bit more how I store it:
I only backup my /home partition (only the important directories) and some /etc files that I changed from the default. Everything else can be retreived by a simple reinstall.
I don’t use backup software. I use cp -au $HOME/{dirlist}/. /media/$USER/backup1 (not the exact command but you get the gist) to an external 2.5" USB3 HDD. I mirror this HDD periodically to a second external 2.5" USB3 HDD. Both HDDs stay offline and are kept in physically separate places.
It is not perfect, but I guess good enough and I’m willing to take the remaining risk. :crossed_fingers:
I just back up /home with Deja Dup though I’ve also backed up using Grsync the last few times also (first one took a while!) and I do that twice a week.I guess if there’s a strategy to be found here is that maybe two is better than one!
@tkn I think that you have a very good approach since it works for you!
There are many ways to back up the system. The important thing is to create a backup that allows you to recover to a working environment after a failure. I believe that your approach will do just that.
