Backup Tactics - rsync - performing checksum or not?
I don’t currently use the “–checksum” option for rsync.
My context, I don’t do partials. Every backup is a “full” backup.
If you currently use that regularly,
  1. Under what context do you use it?
  2. When you use it, what is the factor by which the backup time increases?
I dont use the checksum option. My typical /etc/cron.hourly/ is
/usr/bin/rsync -av --delete /home/user/share/ /home/user/test
share:  remote mount SRC
test:   remote mount DST
--delete keeps SRC and DST the same
Thank you, Pavlos. I appreciate your sharing that.
Frequency of Backup
Out of curiosity, is the “hourly” job for a business production environment or a home desktop environment?
Aren’t you concerned that the endless repeated disk “scanning” won’t eventually de-magnetize the inode indexes to the point that the data becomes non-readable? One of the reasons why I partition my disks the way I do is to be able to “rebuild” a fresh “imprint” of the inode tree every 2 years then re-load the data back onto my main drive from the backup image which, incidentally, is why I was asking if I should, now and then, perform the backup with checksum to ensure I don’t create a backup containing corruption. :frowning:
But before doing that, I wanted a sense of how long it might take for each 300 GB slice?
“–delete”
My own process uses “–delete-during”, which I believe amounts to the same thing as “–delete”. :slight_smile:
Monitoring Backup
For those interested, the below is the output of my “backup monitor” script, which reports info about the rsync job which is running in background.
The yellow highlight is to make the full path to the source directory (represented by the short-form “./” used for the command) … in this case “/DB001_F3” … stands out visibly.
OS_Admin__partitionMirror_Monitor.sh
#!/bin/sh
$Id: OS_Admin__partitionMirror_Monitor.sh,v 1.3 2022/08/05 03:46:55 root Exp root $
This script is intended to perform an ongoing scan to report when an active RSYNC backup process terminates.
test_STEP1()
echo “root 7520 7514 12 20:50 pts/0 00:05:46 rsync --checksum --one-file-system --recursive --outbuf=Line --links --perms --times --group --owner --devices --specials --verbose --out-format=%t|%i|%M|%b|%f| --delete-delay --whole-file --human-readable --protect-args --ignore-errors --msgs2stderr ./ /DB001_F7/
root 7514 7512 0 20:50 pts/0 00:00:25 rsync --checksum --one-file-system --recursive --outbuf=Line --links --perms --times --group --owner --devices --specials --verbose --out-format=%t|%i|%M|%b|%f| --delete-delay --whole-file --human-readable --protect-args --ignore-errors --msgs2stderr ./ /DB001_F7/
root 7512 1 17 20:50 pts/0 00:08:27 rsync --checksum --one-file-system --recursive --outbuf=Line --links --perms --times --group --owner --devices --specials --verbose --out-format=%t|%i|%M|%b|%f| --delete-delay --whole-file --human-readable --protect-args --ignore-errors --msgs2stderr ./ /DB001_F7/” >${TMP}
awk ‘{ printf(“\trsync|%s\n”, $0 ) ; }’ ${TMP}
echo “”
test_STEP2()
echo “7520
7514
7512” >${TMP}.pid
awk ‘{ printf(“\t pid |%s\n”, $0 ) ; }’ ${TMP}.pid
echo “”
test_STEP3()
echo “7514|7520
7512|7514
1|7512” >${TMP}.ppid
awk ‘{ printf(“\tppid |%s\n”, $0 ) ; }’ ${TMP}.ppid
echo “”
. $Oasis/bin/INCLUDES__TerminalEscape_SGR.bh
BASE=basename "$0" ".sh"
TMP=“/tmp/tmp.${BASE}.$$”
now=“$(date | awk '{ printf(”\n\t %s\n\n", $0 ) ; }’ )"
echo “${now}”
if [ “$1” = “–snapshots” ]
then
SNAP=1
else
SNAP=0
fi
rm -f ${TMP}
ps -ef 2>&1 | grep -v grep | grep rsync | sort -r >${TMP}
#test_STEP1
if [ ! -s ${TMP} ]
then
echo “\t RSYNC process is ${redON}not${redOFF} running (or has already ${greenON}terminated${greenOFF}).\n”
exit 0
fi
awk ‘{ print $2 }’ <${TMP} >${TMP}.pid
#test_STEP2
awk ‘{ printf(“%s|%s\n”, $3, $2) }’ <${TMP} >${TMP}.ppid
#test_STEP3
for pid in cut -f1 -d\| ${TMP}.ppid
do
PPID=grep ${pid} ${TMP}.pid
PID=grep '^'${pid} ${TMP}.ppid | cut -f2 -d\|
PRNT=grep '^'${pid} ${TMP}.ppid | cut -f1 -d\|
if [ ( -n “${PPID}” ) -a ( “${PRNT}” -ne 1 ) ]
then
descr=“child”
echo “\t PID ${PID} is RSYNC ${cyanON}${italicON}${descr}${italicOFF}${cyanOFF} process …”
else
descr=“MASTER”
echo “\t PID ${PID} is RSYNC ${yellowON}${descr}${yellowOFF} process …”
fi
done
getRsyncProcessStatus()
testor=ps -ef 2>&1 | awk -v THIS="${PID}" '{ if( $2 == THIS ){ print $0 } ; }'
MODE=echo "${testor}" | awk '{ if( $NF ~ /^[/]DB001_F?[/]/ ){ print "2" }else{ print "1" } ; }' 2>>/dev/null
if [ ${MODE} -eq 2 ]
then
echo “\t RSYNC restore process under way …”
INTERVAL=60
group5min=5
else
echo “\t RSYNC backup process under way …”
INTERVAL=10
group5min=30
fi
if [ -n “${testor}” ]
then
echo “\n\t ${testor}\n” | sed ‘s±-+\n\t\t\t\t–+g’ | awk ‘{
rLOC=index($0,“rsync”) ;
if( rLOC != 0 ){
sBeg=sprintf(“%s”, substr($0,1,rLOC-1) ) ;
sEnd=sprintf(“%s”, substr($0,rLOC+5) ) ;
sMid=“\033[91;1mrsync\033[0m” ;
printf(“%s%s%s\n”, sBeg, sMid, sEnd) ;
}else{
pLOC=index($0,“/DB001_”) ;
if( pLOC != 0 ){
sBeg=sprintf(“%s”, substr($0,1,pLOC-1) ) ;
sEnd=sprintf(“%s”, substr($0,pLOC) ) ;
printf(“%s\033[1m\033[93;1m%s\033[0m\n”, sBeg, sEnd) ;
}else{
print $0 ;
echo “\n\t Scanning at ${INTERVAL} second intervals …”
test ${SNAP} -eq 1 || echo “\t \c”
fi
durationCumulative=0
lapseCount=0
lapse=0
if [ ${SNAP} -eq 1 ]
then
while true
do
if [ -z “${testor}” ]
then
echo “\n\n\t RSYNC process (# ${PID}) has ${greenON}completed${greenOFF}.\n”
echo “${now}”
date | awk ‘{ printf(“\t %s\n\n”, $0 ) ; }’
exit 0
fi
jobLog=ls -tr /site/Z_backup.*.err | tail -1
echo “\t tail -1 ${jobLog}”
sleep ${INTERVAL}
done 2>&1 | uniq
else
while true
do
then
echo “${now}”
exit 0
fi
echo “.\c”
durationCumulative=expr ${durationCumulative} + 1
if [ ${durationCumulative} -eq ${group5min} ]
then
lapseCount=expr ${lapseCount} + 1
lapse=expr ${lapseCount} \* 5
echo " ${lapse} min\n\t \c"
fi
sleep ${INTERVAL}
done
fi
exit 0
exit 0
exit 0
#!/bin/sh
$Id: INCLUDES__TerminalEscape_SGR.bh,v 1.2 2022/09/03 01:57:31 root Exp root $
This includes string variables defined to perform various substitutions for the ANSI Terminal Escape Sequences, i.e. SGR (Select Graphic Rendition subset)
REFERENCE: ANSI escape code - Wikipedia
ECMA-48 - Ecma International
“\e” is same as “\033”
style_e()
boldON=“\e[1m”
boldOFF=“\e[0m”
italicON=“\e[3m”
italicOFF=“\e[0m”
underlineON=“\e[4m”
underlineOFF=“\e[0m”
blinkON=“\e[5m”
blinkOFF=“\e[0m”
blackON=“\e[30;1m”
blackOFF=“\e[0m”
cyanON=“\e[96;1m”
cyanOFF=“\e[0m”
cyanDarkON=“\e[36;1m”
cyanDarkOFF=“\e[0m”
greenON=“\e[92;1m”
greenOFF=“\e[0m”
yellowON=“\e[93;1m”
yellowOFF=“\e[0m”
redON=“\e[91;1m”
redOFF=“\e[0m”
orangeON=“\e[33;1m”
orangeOFF=“\e[0m”
blueON=“\e[94;1m”
blueOFF=“\e[0m”
blueSteelON=“\e[34;1m”
blueSteelOFF=“\e[0m”
darkBlueON=“\e[38:5:12m”
darkBlueOFF=“\e[0m”
magentaON=“\e[95;1m”
magentaOFF=“\e[0m”
redBgON=“\e[101;1m”
redBgOFF=“\e[0m”
whiteBgON=“\e[107;1m”
whiteBgOFF=“\e[0m”
style_o()
boldON=“\033[1m”
boldOFF=“\033[0m”
italicON=“\033[3m”
italicOFF=“\033[0m”
underlineON=“\033[4m”
underlineOFF=“\033[0m”
blinkON=“\033[5m”
blinkOFF=“\033[0m”
blackON=“\033[38:5:16m”
blackOFF=“\033[0m”
whiteON=“\033[97;1m”
whiteOFF=“\033[0m”
cyanON=“\033[96;1m”
cyanOFF=“\033[0m”
cyanDarkON=“\033[36;1m”
cyanDarkOFF=“\033[0m”
greenON=“\033[92;1m”
greenOFF=“\033[0m”
yellowON=“\033[93;1m”
yellowOFF=“\033[0m”
redON=“\033[91;1m”
redOFF=“\033[0m”
orangeON=“\033[33;1m”
orangeOFF=“\033[0m”
blueON=“\033[94;1m”
blueOFF=“\033[0m”
blueSteelON=“\033[34;1m”
blueSteelOFF=“\033[0m”
darkBlueON=“\033[38:5:12m”
darkBlueOFF=“\033[0m”
magentaON=“\033[95;1m”
magentaOFF=“\033[0m”
redBgON=“\033[101;1m”
redBgOFF=“\033[0m”
whiteBgON=“\033[107;1m”
whiteBgOFF=“\033[0m”
blackBgON=“\033[40;1m”
blackBgON=“\033[48:5:233m”
blackBgON=“\033[48:5:0m”
blackBgOFF=“\033[0m”
cyanBgON=“\033[106;1m”
cyanBgOFF=“\033[0m”
cyanDarkBgON=“\033[46;1m”
cyanDarkBgOFF=“\033[0m”
greenBgON=“\033[102;1m”
greenBgOFF=“\033[0m”
yellowBgON=“\033[103;1m”
yellowBgON=“\033[48:5:214m”
yellowBgOFF=“\033[0m”
redBgON=“\033[48:5:9m”
redBgOFF=“\033[0m”
orangeBgON=“\033[43;1m”
orangeBgOFF=“\033[0m”
blueBgON=“\033[104;1m”
blueBgOFF=“\033[0m”
blueSteelBgON=“\033[44;1m”
blueSteelBgOFF=“\033[0m”
darkBlueBgON=“\033[48:5:12m”
darkBlueBgOFF=“\033[0m”
magentaBgON=“\033[48:5:55m”
magentaBgON=“\033[48:5:93m”
magentaBgOFF=“\033[0m”
#style_e
style_o
Usage Examples:
echo “\t ${PID} is ${cyanON}${italicON}${descr}${italicOFF}${cyanOFF} process …”
echo “\t ${PID} is ${yellowON}${descr}${yellowOFF} process …”
echo “\n\n\t RSYNC process (# ${pid}) has ${greenON}completed${greenOFF}.\n”
Example of scenario where escape codes are hard-coded; \e was not accepted by awk
echo “\n\t ${testor}\n” | sed ‘s±-+\n\t\t\t\t\t\t\t\t–+g’ | awk '{
if( rLOC != 0 ){
}else{
print $0 ;
echo “\n Imported LIBRARY: INCLUDES__TerminalEscape_SGR.bh …\n”
This is for my Lab, I save all notes, configs, testdirs, etc to the NAS which is backed up every hour to two remote mounts. So, at worst, I lost one hour of work. Note that rsync copies files that are different, it does not copy the whole tree.
In Production env, it depends, usually there are nightly backups but if data is critical, they could backup every 12 hours.
Are you concerned about spinning disks MTBF ?
Mean time between failures - Wikipedia
No, Pavlos, not mechanical MTBF.
My concern was more regarding the interraction of reading head and magnetic impression on disk, as per
I did a search on “endless repeated disk “scanning” de-magnetize the inode”. Scanning a disk does not de-magnetize the inode (or the data). It does not emit the strong magnetic fields needed to erase or degrade data.
  • Reading Does Not Degrade Data: Reading a sector on a hard drive relies on electromagnetic induction, which simply detects the magnetic flux of the platter. It causes no wear and tear or demagnetization.
  • The Process of Degaussing: Actual de-magnetization requires a massive, deliberate magnetic pulse from a specialized machine called a degausser. Standard hard drives and file system operations cannot produce forces strong enough to cause accidental degaussing.
Hope this helps.
