Hey everyone
I recently installed Kali on my pc removing windows and the like but my WiFi and Bluetooth stopped showing n working
I’ve tried lots of ways to fix
I tried using Ubuntu’s live environment n Bluetooth appeared and worked
Still no WiFi
Shows probe error code -110
Those who’ve experienced the same issues or maybe u just know how to fix it how do I go about it?
What do y’all think I should do???
It’s a DELL Latitude 5420 and yes I’ve used all those before when I had windows
Greetings to you @Cupid-Inno and welcome to the community. I hope the suggestions provided are sufficient to make some progress; please let us know after you’ve had a chance to read them and try the suggestions provided.
He tried everything. A live USB, new and old kernels, a bunch of driver options, even disconnecting the battery. What finally fixed it was turning off Intel AMT in the BIOS.
AMT is a remote management feature that comes on a lot of business laptops like the Latitudes, and it can hang onto the WiFi card so Linux never gets a response from it. That’s what the -110 is, a timeout. It also explains why the Ubuntu live USB failed too.
To turn it off:
Reboot and tap F2 to get into the BIOS.
Look for Intel AMT. On Dells it’s usually under Manageability, called something like Intel AMT Capability.
Set it to Disabled.
Apply, save, and exit.
Boot back into Kali and the WiFi should show up.
If Bluetooth still doesn’t work after that, plug in ethernet or tether your phone over USB and run:
