Recently my KALI Linux disconnected wlan and show no wifi adapter , although internet is working which i connected while installing , I have tried almost many drivers installing but did’nt work and still i am scratching my head since last week.
if anyone know the solution kindly help
What desktop environment are you using?
For me I’m using I3 with Kali and I had a similar issue. But it was not being able to load the connection page for open WiFi portals.
So I installed Gnome, booted into gnome and it works there. Then when I removed just gnome main packages and left everything else it worked there after no issues.
Strange.
Welcome to the Linux tech community btw! ![]()
Welcome to the forum. I hope you were able to solve this?
Hi @Bilal_Mirza,
Were you able to fix the issue? I had a similar issue when I installed Kali without any desktop environment. I had to install it again with DE, and then the problem was solved.
If you solved the issue, I’m curious about the solution.
