Yeah, something like that!
I here you! Despite the fact that I REALLY like the Gtk+ toolkit, in terms of graphical capabilities, I have NEVER EVER had a fondness for GNOME. When it FIRST came out, I thought I’d like it, but when I found that there was little to zero configurability, I said, “Bye, bye!” But when the Xfce project went from the use of Xforms to Gtk+, I DID like that! Why, you may ask?
Simple; the Xfce methodology allowed me to customize just about everything with text readable, alterable configuration files!
The early KDE had a so-so license, and that’s why other desktops appeared but it had something that the others did not have - you may have guessed - YES - configurable text editable files!
When the Plasma project started, that pretty much took me out of KDE, except to occasionally EXPLORE it. They’ve tamed it over the years and brought back more editable components, but it’s WAY heavier than anything I need. At least it has SOME flexibility.
Readers who have been around for a few weeks or months know that I like text editors and customizable interfaces. I don’t have anywhere near as many things that I want to customize as our friend @machiner, but we at least share a common interest of wanting complete control over what we use.
Since all I absolutely “need” (that’s if using a computer is truly a need, not just a “desire” or a “geek’s drug”) is a Web browser, then I use an editor to be able to write and modify text, and occasionally fairly short, simple scripts and tools, and because of this, a desktop environment is gross overkill for me.
So what’s the simplest interface for me? I pick IceWM as the Window Manager (WM), not because it’s the #1 leanest; these days it’s not the leanest, it just has the most basic config language syntax. Some of the others are text editable, but they insist on using some variation of XML, which I feel on the “simple level” is still overkill;why do that when you just want to specify a FEW things without having to possess a graduate degree in the variations of XML, HTML5+ or whatever? Yes, I can read up and figure out how to use them, but JWM is a great example - it’s an excellent, easy to use, very efficient Window Manager, but it has display elements that are NOT easy to remember unless you work with them constantly; otherwise JWM would be my favorite. WM 2 would be Fluxbox; it has the simple syntax like IceWM, but unless you rewire the keys, requires the use of double buttons or a middle mouse button - why? Openbox is pretty easy, but like the others the syntax for the config file isn’t as simple as the interface for IceWM.
I decided this twenty or more years ago and between 20-30 years back, IceWM also happened to be among the leanest WM; it remains lean today, but a few extra “features” have crept in. Fortunately feature creep has been moderate so I’ve been able to “stick with it”.
So here’s the thing: if you want every trick in the book and you LOVE eye candy, then you probably crave KDE Plasma; it can do just about everything.
That is 100% okay; that’s WHY we have all of these choices. @machiner has what he prefers, and it’s quite interesting what he’s able to do with his stuff, which he’s built up over decades of use and experience.
I also have those decades, but I’ve CUT DOWN my interface because I only NEED a fraction of what I once needed, so I’ve cleaned out a few things. If I get tired of trying out twenty or more different text editors and Web browsers I’ll probably pare down even more stuff; in the meantime, I use a collection of very short alias commands, with many one character aliases to give my lousy typing hands a chance to do what I want without typing out stuff like sudo apt-get update; sudo apt-get upgrade; doom sync; doom upgrade; restartEmacs, and then later killall emacs! Instead I type u;d;re to update my system and start or restart Emacs; when I’m ALL DONE with Emacs I can type ke and the “time efficient” Emacs daemon that I start to make getting in and out of Emacs quick is also something I can ELIMINATE when I’m not planning on using Emacs for a while, or “done for today”.
Well, I CAN type, but NOT all the time; that’s my discourse for today! MY points are all over the place, aren’t they?
