This is NOT a review of KDE vs Gnome vs Cinnamon vs Mate vs whatever. What I do is install the bare minimum straight to tty from each distro that offers that installation.
Full disclosure I did my tests in a virtual machine, VirtualBox, and my criteria is: how much hard drive space did it take just for the base install. Then afterwards I compare a simple Xorg vs Wayland install with a tiling WM so no full blown desktop environment; just to see how much RAM is used in a basic install.
With Debian, when I go to add GDM just to have a graphical login screen it installed the full Gnome desktop experience which was absolutely not what I wanted. After the fact I learned that I could pass “–no-install-recommends” and “–no-install-suggests” to bypass all that. Yeah… mixed results sometimes those command line arguments were ignored.
I also have the same experience with sddm, which is built on Qt. Surprise! KDE Plasma was installed, not what I wanted. Well ok cool, I never seen KDE Plasma before, played with it for a minute but I’m on a virtual machine and it’s sluggish so I quit out.
I also did this same barrage of tests with Fedora and now I feel torn because I like them both.At the end of the day what still irks me is I still don’t have full control of things. For example, I don’t want anything audio related so I don’t want pipewire and oh what’s that other thing something plummer, don’t want services running if I’m not using them. In one case I could simply remove packages I don’t want, in other cases I’m not allowed due to dependencies.
.As far as “minimal” install options go it’s still up to the maintainers to decide what’s the base level. If I really wanted to go minimal there are other options.
I was doing all of this because I’m in a situation where I have limited hardware and my only way forware (edit: forward) as far as OS is Linux. Also I’m bored and have free time ![]()
