Aloha, friends!
Does anyone know a good way to create something like a clipboard like on android?
Like I saved it, and then I can select and paste from it.
And please, advise something that you will trust by yourself, as in clipboard there is many confidential information
I tried Diodon, but it didn’t work.
It is important that it was possible to have clipboard attached to RAM so that when you reboot everything is deleted from it, for security purposes, of course. We all copy something very personal that we don’t want to keep
I want to say XFCE is having it’s own clipboard manager as panel plugin, it might be not as fancy as Windows 11 one, but it’s pretty usable and simple.
