We’ve updated the editor/compose post/message font to look a bit more like a terminal font. It should now be easier and more familiar on our eyes — better suited for technical posts:
Hey @hydn nice update! maybe the font in message editor is a little too small and i’m facing some difficulties reading.. you might increase the size by some points ~~ my opinion
I can see that. The font is naturally a bit smaller. I did try to use larger size, but then it so looked much bigger.
I’ll work on this. Probably will revert because we were all ok with the previous setup. This new font didn’t “fix” anything. Maybe, as your feedback indicates, it has done the opposite for some portion of users.
Bumping this in case anyone needs to manually unpin any topics.
Also, don’t forget you can bookmark any of the current topics/discussions that you are active in or want to save for later. Useful for any guides or solved threads that you want to easily find agan in the future:
