Network usage util
Hello :slight_smile:
while today using my normal system I usually open btop to check the amount of data been used since I booted up my machine ,but every second matter I don’t wanna waste 0.5 second wait for btop to load and keep staring at network block
I made simple solution Introducing
nwusage
small cli to read network bits from kernel and stdout
nwusage -hr
I bind key for fast checking
bindsym $mod+N exec --no-startup-id notify-send "Network Data Usage" "$(nwusage -hr)" -t 5000
and yes I tried bash it work but slower and cause problems in my i3 configs
I share this in case someone found it useful.
Followed. Thanks for sharing. You should probably update the repo page with screenshot and some more details when you get a chance.
Thank you I’ve updated the polished repository :sparkles:
works like a charm :slight_smile:
