Netdata on a Mostly-Idle Home Server: Worth It
2 days ago I installed Netdata. Which always stands out for how easy it is to get up and running. Literally thousands of metrics in less than 3 minutes to install after pasting a single install command in terminal.
Why Netdata
This is one of those tools where you install it, open a browser, and you’re already seeing useful data without spending hours tuning or wiring things together.
Who Netdata Is For
Netdata makes the most sense for people who want deep visibility into a system without turning monitoring into a project of its own. Home lab users, small servers, single VPS setups, or even a lone desktop or mini PC running services are a perfect fit. It gives you real-time insight into CPU, memory, disk, network, Docker containers, and applications with almost no effort.
My Setup
I’ve disabled CPU turbo in the BIOS and enabled power-saving options to keep power usage down.
My setup is a Lenovo ThinkCentre Tiny that mostly sits idle. Originally it was just running a UniFi controller, which already lives in Docker. Over time I added a few more services and containers, including some light web hosting and background services. Nothing heavy, which is exactly why Netdata appealed to me. When a system is quiet most of the time, you actually want good visibility into the brief spikes, background activity, or unexpected behavior.
What Netdata Does Well
Netdata shines here. The dashboard is fast, clean, and extremely detailed. You can drill down from high-level system health to per-core CPU usage, disk I/O patterns, network traffic, and even individual Docker containers. The built-in charts make it easy to spot trends or confirm that “nothing weird is happening,” which is often the goal on a small server.
Pricing and Personal Use
Another big plus is that Netdata is free for personal use for up to 5 nodes. You can run it locally, keep all the data on your own system, and never touch the cloud if you don’t want to. For anyone running a single box at home or a couple of machines, it’s worth checking out.
What Are You Using?
I’m curious if others here are using Netdata already, and if so, what kind of setups you’re running it on? Or what other monitoring/observability solution(s) do you use/recommend?
Anyways, check them out:
Related reading
I’ve been running netdata on a few boxes here and I’m impressed by how much info it presents, and how beautifully it does it, with no special effort required.
Netdata seems cool and presents the data quite well! I am stuck in my ways so I don’t see using them on my own systems right now, but, it looks like a great recommendation for some friends of mine.
Right now, I use the Node Exporter (and all the other exporters), Prometheus, Grafana stack for the visibility side of things. Where an exporter does not exist, I write my own scripts, push them to a directory Node Exporter is configured to scrape from, and ingest the data that way.
I also use Nagios/Icinga for monitoring and Monit for monitoring and self healing where possible (Monit can be disruptive if set up incorrectly, so I don’t use it everywhere).
Below are some screenshots from my Grafana instance, the first two are from default Node Exporter and Postfix Exporter, the last two are from my own scripts gathering data (will provide my GitHub links to those if you are interested. I am an amateur, so bear that in mind haha). Thought it’d be fun to share some images from Grafana, if they are off-topic or irrelevant I can remove them!
This is from Node Exporter (the uptime was from patch day today)
This is from Postfix Exporter. I host my own email, it’s not very busy but it does get spammers hitting ports quite often, so I use this to monitor for large amounts of connection attempts/rejections.
This is one of my scripts to monitor AT&T because they constantly are messing (read breaking) their network routes, especially their exit nodes. So I wrote a Python script that wraps around the MTR application to track network performance to key IPs. Ping Stats Repo
I host a Minecraft server for me and the family to play on together, along with some friends. This is just the tip of what I show in the dashboard, but it’s fun to visualize Minecraft stats over time. (yes, I blurred out actual usernames here). Owencraft Stats Repo
Update: I’, uninstalling Netdata today. It’s using too much resources on my Lenovo Tiny:
Now to be fair, the CPU has been intentionally locked to 800 MHz to reduce homelab watts and thus also more importantly reduce heat inside the rack. So this could also be solve by just enabling the CPU to clock up to 3.6 GHz:
But with no air conditioning in the room, I prefer to just keep CheckMk and remove Netdata.
I probably could have tweaked it to reduce the amount of data collected. But it was really mostly overkill already as nothing very critical is running on the server.
