[utils] Bytes cli
Hello every
I just wrote a util for my self called Bytes it’s a cli that print file size in human readable format blazingly fast
I know it’s not that big of deal to list file size kinda silly but here the cause
I’m really pissed off while using ls -lh it slow and the other alternative tools seems clunky too , I fire up my neovim clang++ lsp and some docs and made this tiny fast util
Screenshots / comparison
branding
Git repository
Bytes
Nice job! :smiling_face_with_sunglasses:
Honestly, not silly at all—ls -lh is slower than it should be, especially on large directories. I like the idea of having a purpose-built CLI tool that does just one thing fast and clean.
Just tested bytes—it’s snappy. Also cool that you’re using clang++ and had LSP in Neovim ready to go. Would be neat to support piped input later on. Like:
find . -type f | bytes
…but as-is, it’s solid!
Cheers for sharing!
thanks for nice words, it will kept me motivated :smiley:
And yes I’ll do more feature updates later on.
@Halano very nice! I will test it out. I have been using lsd for a long time as ls replacement but this is not always fast
I use lsd too , it’s slow that why I made bytes in first place
very nice!
thank you .
@Halano
Another option is using the native command: du -h, it’s output is very similar. Here an example of usage:
As you can see your software is more accurate then native command.
Great project btw, you had very great idea.
thanks @ricky89
but 2 MB of x11 errors is wild :smile:
You got this :+1:
Yes indeed 2MB of x11 errors are crazy :laughing:
The fact is yesterday evening I was using a software as multimedia streamer (MPV) that was adding debug logs strings about MB/s and framerate on xsession errors file content. As you can you see in this github issue:
It’s a well known software issue. Author said there’s not coding solution, the only idea is launching the software from CLI with some specific arguments, or create a desktop launcher with those parameters.
For now I just turned off xsession errors because I’m using multimedia stream quite often.
@Halano
Yesterday evening tested in a VM (ArcoLinux).
After sh compile, the file bytes appears but it can not start.
show logs , error or screenshot ?
So I can detect your problem.
Wich logs do you need? The terminal says nothing :frowning:
So testet again with an xubuntu VM
:rofl: that’s hilarious
move it to your path or run it directly, like that
./bytes bytes
./bytes <path-to-file>
it should print the size of it
Ok this worked. My fault… :frowning:
oh man
