[Go] cert-checker
I believe, yes, it is better.
todays progress:
Searchbar, auto refresh with options
Testet with WSL (Ubuntu) and it works, nice :slight_smile:
Update to Version 1.1.8
GitHub readme is updated as well.
Bigger release to Version 1.2.
@ugnvs
I think you are doing very well. Your cert-checker becomes more and more mature and powerful. Cheers!
I’d like propose that you evaluate the following idea. Namely, you might want to give your cert-checker several modes of operation and UI. Say, “simple” vs “full”, “basic” > “extended” > “advanced”, “essential” vs “in-depth”, verbosity levels, etc. Simple and basic modes would allow for quick no-nonsense certificate verification and not overwhelm user with abundance of information and UI controls. More advanced modes would add more and more details for technically savvy users.
Very good idea.
My first try for basic output
Yep, that is the same output that I got.
b.t.w. I copied all my up-to-date certs to the cert folder to see if cert-checker could read it and ofcourse it can :blush:
Question: is there a way to change the path to the certs directory?
How can I point it to the folder where my automatically updated certs already reside.
cool, thank you.
Of course you can. The latest version has a config file (config.ini)
# cert-checker Configuration File
# Created automatically on first run
# Lines starting with '#' are comments
[paths]
# Path to URL list (supports ~, /or relative path)
urls_file = ~/.config/cert-checker/urls.txt
# Path to the log file
log_file = ~/.config/cert-checker/logs/cert-check.log
# Directory for JSON reports
report_dir = ~/.config/cert-checker/reports
# Directory for certificate files
cert_dir = ~/.config/cert-checker/certs
[settings]
# Timeout in seconds for network checks (default: 60)
timeout = 60
# Default webserver port
web_port = 9090
cert_dir is the setting you need
New release:
Nice work on v1.3, the markdown export is a solid addition.
One feature idea, since you’re already tracking cert expiry per URL: might be worth also flagging domain expiry alongside it. A cert can be perfectly valid but the domain itself lapses (happens more often than people think), and that’s a blind spot most cert-monitoring tools don’t cover.
If you don’t want to build a full WHOIS parser from scratch, WhoisFreaks has an API that just returns expiration date + registrar info for a domain, could slot into your existing report loop pretty easily. Just a thought if you’re looking for what to add next.
Welcome, @Furqan_Ashraf to the community! :handshake:
