Zoom version 7 woes - side bar remains blank
Hi guys
I downloaded Zoom for linux version 7. I am running Ubuntu 24.04.
The side bar remains blank, where normally the scheduled meetings should show.
Also I was unable to schedule any new meetings ..there is no response from the schedule button.
As a result, i uninstalled version 7 and have gone back to the earlier version.
Any inputs from anyone will be welcome :folded_hands:
This issue is likely tied to missing dependencies or a permission conflict with the Wayland display server, which Ubuntu 24.04 uses by default.
  1. Install missding dependencies
    sudo apt update && sudo apt install libegl1-mesa libgl1-mesa-glx libxcb-xtest0 libxcb-cursor0
  2. clear the zoom cache
    rm -rf ~/.config/zoom
  3. Try logging out and selecting “Ubuntu on Xorg” from the cogwheel icon at the login screen to see if functionality returns.
4)Use the Official .deb
sudo apt install ./zoom_amd64.deb
Thank you. Will do that and see
That problem is most likely related to Wayland compatibility in Ubuntu 24.04.
The current Linux Zoom client still relies on several X11-based components, and under Wayland certain Ul elements (such as the sidebar or scheduling dialog) may fail to load.
1. Install the required graphics dependencies
Some Zoom Ul components rely on OpenGL and XCB libraries.
Missing packages can cause blank panels or unresponsive buttons.
sudo apt update
sudo apt install libegl1-mesa libgl1-mesa-glx libxcb-xtest0 libxcb-cursor0 xdg-desktop-portal xdg-desktop-portal-gtk
These libraries provide the OpenGL and desktop-portal interfaces required by Zoom’s Electron-based interface.
2. Clear the Zoom configuration cache
Corrupted configuration files may prevent the sidebar modules from loading.
rm -rf \~/.config/zoom
rm -rf \~/.cache/zoom
Then restart Zoom.
3. Verify which display server is running
Run on terminal:
echo $XDG SESSION_TYPE
If the output is:
wayland
then Zoom is running under Wayland.
4. Switch to Xorg (recommended fix)
Many Zoom Linux Ul issues disappear immediately when running under X11 instead of Wayland.
Steps:
  • Log out of Ubuntu
  • On the login screen click the gear icon
  • Select “Ubuntu on Xorg”
  • Log in again and start Zoom
Switching to X11 resolves many Linux screen-sharing and UI problems because Wayland currently has stricter security restrictions for screen capture and window control.
5. Reinstall Zoom from the official package
Avoid unofficial Snap builds or outdated packages.
Download the official package and install it:
sudo apt remove zoom
That problem is also there is on zoom community
Thank you. I will try that out.
I tried on 26.04.(usb live). zoom works flawlessly there
I am having the same issue.
No dependencies are missing.
I have tried to update to 26.04 but the distro is being phased.
I tried wayland=true AND wayland=false.
Running $ echo $XDG SESSION_TYPE gives SESSION_TYPE
I am not sure what else to try.
Hi. I have rolled back zoom to an earlier release 6.5
This works ok on 26.04
So perhaps the issue is in the zoom 7.0.0
Thanks! I just downgraded to 6.7 and it works properly now. The issue is indeed with 7.0.0
Hi, @lauren_olamina :smiley:
Welcome to the community!
Thanks @Ravi_E seems this is a 7+ issued. @lauren_olamina thanks for also confirming
It would appear that Zoom 7.xx has an issue with Wayland.
I use the Zoom7.xx on my Ubuntu MATE 24.04.4 (X11 session) without issue.
Only a minor typo (happens to me all the time)
$XDG_SESSION_TYPE
You missed the first underscore.
If you try again it will echo either x11 or wayland
Ooof! Thanks. That works now
