After following Zoom instructions, the result is
`Unsupported file ./zoom_amd64.deb given on command line
Nice to see you again. Can you share:
- Your Zorin version
- How you downloaded the file. (wget?)
- Output of
file zoom_amd64.debandls -lh zoom_amd64.deb
Did you try this:
Zorin 17.3 Pro. Thanks James! I tried your box for installing Zoom, and it worked!
Different issue here as well…my HP printer is not responding to commands. Should I remove and re-install?
