SpeakoFlow: offline voice typing and a voice assistant for Linux
Hi everyone,
I’m Abhishek, a solo developer from Nepal. I made SpeakoFlow, a free, open-source voice app for Linux (also Windows and Mac), and 2.2.0 just came out with a few Linux fixes.
demo
What it can do:
  • Talk and it types, in any app, like your terminal, browser or LibreOffice
  • Select some text and ask it to translate it, reply to it or explain it
  • Ask the assistant anything. It can search the web, or look at your screen if you let it
  • Have a spoken conversation where it talks back, and you can cut in while it’s talking
  • Write up your meetings with a summary and next steps, without a bot joining the call
It all runs on your own computer, no cloud or account needed. You can download any model from Hugging Face right in the app, or use ones you already have.
It’s MIT licensed, and everything’s on GitHub:
If you give it a try, I’d love to hear what you think.
Welcome to the community @AbhishekBarali, thanks for sharing! :handshake:
Downloading with the intent to try later in the day - love it. I want my neighbors to start looking at me funny becuase we’re all a little too cozy around here. lI can’t wait for them to hear me pacing and talking to the ether…THanks for the project.
Thanks John, glad to be here!
I looked over the project and it looks great! I’d definitely use it, only one problem, for Rust I have Cargo installed and for me to install RustUp I’d have to remove it (It’s for another app I use from GITHUB). So I’ll have to think it over.
Warm greetings and welcome to the community!
TOok me forever to gedt back - - sorry. I tried your app and it was immediately fabulous - hit c’tarl+space and talk and that’s it. I loved it. I did not try any ai features - all I did was open it, hit the keys and speak.
I tried it a couple days later again and it didn’t work as well. FIre it up, hit c’tarl+space and talk…nothing; I couldn’t see any text appear as I had earlier. I hit c’tarl+space again and there was the text I just spoke. Hmmm.
Only other thing running on my box either time was a browser (helium).
EDIT: I need pipewire?
🕒 10:55:44 ✔  ~/Downloads ❓96%
→ ./SpeakoFlow_2.2.0_amd64.AppImage
/usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so: undefined symbol: g_variant_builder_init_static
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
[2026-11-02][15:55:50][speakoflow_app_lib::managers::history][INFO] Initializing database at "/home/machiner/.local/share/com.abhishekbarali.speakoflow/history.db"
(speakoflow:19071): libayatana-appindicator-WARNING **: 10:55:50.871: libayatana-appindicator is deprecated. Please use libayatana-appindicator-glib in newly written code.
[2026-11-02][15:55:50][transcribe_worker][INFO] [transcribe_cpp] load_backend: loaded CPU backend from /tmp/.mount_SpeakocAhBnA/usr/lib/libggml-cpu-haswell.so
[2026-11-02][15:55:50][transcribe_worker][INFO] [transcribe_cpp] transcribe_init_backends: 1 compute device(s) registered after scanning /tmp/.mount_SpeakocAhBnA/usr/lib: CPU
[2026-11-02][15:55:50][transcribe_worker][INFO] [speakoflow_app_lib::engine_supervisor::worker] transcribe.cpp 0.4.0 initialized with 1 compute device(s): [Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz (cpu, Cpu)]
[2026-11-02][15:55:51][speakoflow_app_lib::updates][INFO] Update support: InApp (bundle Some(AppImage), portable false)
[2026-11-02][15:55:51][speakoflow_app_lib::commands][INFO] Enigo initialized successfully after permission grant
[2026-11-02][15:55:51][speakoflow_app_lib::commands][INFO] Shortcuts initialized successfully
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM pipewire
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:404:(_snd_pcm_oss_open) Cannot open device /dev/dsp
[2026-11-02][15:55:55][transcribe_worker][INFO] [transcribe_cpp] load_backend: loaded CPU backend from /tmp/.mount_SpeakocAhBnA/usr/lib/libggml-cpu-haswell.so
[2026-11-02][15:55:55][transcribe_worker][INFO] [transcribe_cpp] transcribe_init_backends: 1 compute device(s) registered after scanning /tmp/.mount_SpeakocAhBnA/usr/lib: CPU
[2026-11-02][15:55:55][transcribe_worker][INFO] [speakoflow_app_lib::engine_supervisor::worker] transcribe.cpp 0.4.0 initialized with 1 compute device(s): [Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz (cpu, Cpu)]
[2026-11-02][15:55:55][speakoflow_app_lib::audio_toolkit::audio::recorder][INFO] Using device: Ok("default")
Sample rate: 44100
Channels: 1
Format: F32
[2026-11-02][15:55:55][speakoflow_app_lib::managers::audio][INFO] Microphone stream initialized in 86.283415ms
[2026-11-02][15:55:56][transcribe_worker][INFO] [transcribe_cpp] parakeet: promoted 48 conv pointwise weights from F16 → F32 for CPU backend
[2026-11-02][15:55:56][speakoflow_app_lib::managers::transcription][INFO] Loaded transcribe.cpp model parakeet-unified-en-0.6b-gguf (arch=parakeet, variant=unified-en-0.6b, backend=CPU, device=Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz [CPU], cpu_threads=all)
[2026-11-02][15:56:09][speakoflow_app_lib::smart_spacing][INFO] Smart spacing: from nothing (unknown): space before false, space after false, lowercased false, selection case false, final mark dropped false, own period removed false
[2026-11-02][15:56:17][speakoflow_app_lib::audio_toolkit::audio::recorder][INFO] Using device: Ok("default")
Sample rate: 44100
Channels: 1
Format: F32
[2026-11-02][15:56:17][speakoflow_app_lib::managers::audio][INFO] Microphone stream initialized in 2.985468ms
[2026-11-02][15:56:24][speakoflow_app_lib::smart_spacing][INFO] Smart spacing: from nothing (unknown): space before false, space after false, lowercased false, selection case false, final mark dropped false, own period removed false
sneaky edit becuase I didn’t have much time earlier: I do plan to use it thoroughly and break into some of those cool features. Will update.
(post deleted by author)
According to the logs: either pipewire of J.A.C.K.
