I’m using Gnome(wayland) on Arch Linux. I reinstalled it today. When I’m maximizing some app, such as gnome-terminal, Ghostty, gnome-files. But in normal view its all normal. How can I fix that problem?
Are you using NVIDIA graphics by any chance?
No, it’s an AMD GPU. Anyway, I switched to KDE today for this problem.
Had the same problem in Gnome. If you disable Variable Refresh Rate for that screen, the problem goes away. Just a workaround if you can live without VRR.
Welcome to the forums. Thanks for joining and adding that!
