Arch Linux - problems and resolutions
So here I am again.
With this post I want to create some Arch troubleshooting guideline, I start the conversation with the problem I found and I was able to fix.
In one of last topics I said I found some updates in Arch that broke a sofware compatibility.
Two days ago I tried switch my workflow to an Arch Linux virtual machine and I found the same problem on the software, after activating the 3d graphic card acceleration.
So I was wondering if it’s a bug or what, since after almost 10 months ago it’s not fixed yet.
The problem I had was using Kreya (as api client) and IPTVnator (as multimedia broadcaster), both this software are using libwebgtk and on both of the softwares I had a blank window without any controls.
I did not saw this problem with Debian or Linux Lite because they are using an old library version.
I went deeply and looking at system logs there was some dumps in gtk libraries and javascript core frameworks. I understood that last updates (since gtk version 4.3) they add a feature for improve hardware acceleration. It seems this improvment have some issues with Nvidia cards, I own an RTX 3070ti, I fixed my problem by disabling this feature.
As I googled I found this topic [[bug] Tauri 2.0.0-rc shows blank window after upgrading to webkit2gtk-4.1 2.44.3-2 · Issue #10626 · tauri-apps/tauri · GitHub] and all I did was create a system wide variable: WEBKIT_DISABLE_DMABUF_RENDERER and set its value to 1. After creating this variable bothe the softwares starts working again.
I lost my last 2 days tring fixing this problem, it might be usefoul to some others users.
ricky
One thing I found helpful when using Arch was to run it with an LTS kernel:
I found another stability issue:
I’m using the password manager gui keepassxc, when launching the program normally theres some huge icons, as you can see in this image:
I found the solution on this github repo, they saying there’s some scale issues on last gtk version:
So i created my sh launcher as the following:
now the software is working with correct icon size:
It might be usefoul if someone encountred the same problem using keepassxc or some gtk application under Linux.
ricky
Edit:
on Arch Linux I’m using the default Kernel mainline, until now I never found some problems (I’m on Arch for less then 1 month now :slight_smile: )
I will keep in mind about using LTS Kernel if I will encounter some issue.
Thanks for sharing it.
Here am I again, sorry for my absence but I was quite busy ~~
I’m having another problem on my Arch installation since yesterday: the file ~/.xsession-errors on my home folder is huge increasing, almost half megabyte for minute.
The issue is a cryptic log that is spamming the file ~~ each 200ms: here is a small portion of the file:
From the log I understood is some xfwm component that is trying to access to a database table which does not exists yet.
I want to resolve this problem, does someone come into this recently? Can someone help me identify which is the cause?
For now I created a startup script that will delete the log file at user login so I don’t have problems because the file does not exists, but this is not the correct way for solve this problem.
Hey @ricky89
So here’s a breakdown of the error:
  1. GLib-CRITICAL: This is a runtime error in a program using the GLib library. GLib is used in many Linux desktop environments, including Xfce and its components like xfwm.
  2. g_hash_table_lookup: This is a GLib function. It looks up a key in a hash table and returns the corresponding value. If the hash table is invalid or uninitialized, it fails.
  3. assertion 'hash_table != NULL' failed: The error means g_hash_table_lookup was called with a NULL (non-existent) hash table. This looks like a programming error, it’s likely the developer didn’t check whether the hash table was initialized before using it or other related issue.
In any case report it to: https://bugzilla.xfce.org/
Also read: Bug reporting guidelines - ArchWiki
Consider a less bleeding-edge rolling distro like Void Linux (features stable rolling release), Tumbleweed (also stable rolling) or Kali Linux (without pentesting tools, would be in the middle between Arch and those other two).
Thanks @hydn for the detailed explanation, the problem is I neither don’t know which piece of software is causing this log, I suspect it’s xfwm but I’m not sure.
The only thing I did was upgrading the system, for test if it’s a fresh software problem maybe some other Arch users in this forum recently updated their system they might encountered the same bug.
I’m afraid to open a bug report, I’m not sure it’s a bug or if it’s some bad configuration on my system… the odd thing is I notice only yesterday afternoon that log file was becoming huge.
@ricky89 have you checked the journal?
journalctl | grep GLib-CRITICAL
@toadie yes I check the logs, there was nothing sospicious, that line was written in log many times every seconds, journalctl was silent, and grep did not filtering nothing.
Btw I found the problem and I was able to fix it:
The problem was the custom compositor Picom (this package) that is not updated for a while now and it’s becoming obsolete.
All I did was disabling the compositor, check the size of ~/.xsession-errors file that was stable and at that point I was sure and I launch the command yay -Rnf picom, followed by removing picom startup script.
After all of that all my system went ok and ~/.xsession-errors file size is now tiny, I will miss a bit the fancy window composition :] but in the end who cares.
Btw I was pretty sure it was not a bug in xfwm because I did not found any recent google result and my problem was too specific.
Sorry guys if I wasted a bit of your time but thanks for your help, I really appreciated.
Hey, nice to hear you fixed the problem. No for me it dosent feels like wasting time. More like good to know and hey, we are here for help :wink:
No no no, this is never a waste of time. Trust me, if anyone else ever has the same issue as you and does a search, he will come across this resolution and will be very happy that you posted it.
This is exactly how the linux community works. These type of posts have helped me to solve many software and hardware problems.
