[QUESTION] QR codes
So… I got situation where I need to scan QR codes from my webcam…
I tried QtQR - it doesn’t see my webcam. Tried https://flathub.org/apps/com.belmoussaoui.Decoder - image freezes when scanning
Same goes with https://flathub.org/apps/details/org.gnome.Snapshot - image freezes (it is working, but super slow reaction to objects in camera view)
But if I install it via sudo apt install gnome-snapshot it doesn’t lag. So it seems as flatpak issue.
Well. Do you know any .deb simple QR decoders that can work directly frem webcam, without need to first take a pic then scan.
I need privacy-friendly solutions (so “just google QR scanner. thats it.” not needed).
Classic Flatpak sandbox issue. Try zbar. sudo apt install zbar-tools and run zbarcam. Bare bones but fast no cloud anything. What distro are you on?
Mint 22.3.
Is it fixable?
Seems to work. Added zbarcam to hot keys for convenience
