Hey y’all!
I’m looking for some input on potential MDM solutions for Linux workstations. Are there any robust systems similar to Jamf out there for Linux? On-Prem or Cloud-based are both fine.
Hey y’all!
Very good and interesting question. Unfortunately, I cannot answer them, but I would be interested.
You won’t find a Jamf-level MDM for Linux with the same polish, but there are solid options depending on what you’re trying to control.
FleetDM is probably your best open-source bet. It uses osquery under the hood, works well cross-platform, and can give decent visibility and control over Linux endpoints. Self-hosted or cloud.
Scalefusion and SureMDM (42Gears) both support Linux (Ubuntu, Debian, RHEL, etc.). They offer remote access, patching, and kiosk mode — more complete MDM feature sets but commercial.
If you’re in a mixed environment, JumpCloud or ManageEngine Endpoint Central are worth looking at too. Both support Linux and are cloud-based.
Keep in mind Linux is still a second-class citizen in MDM land.
Most of these solutions assume you’re okay managing via scripts or agents. There’s no silver bullet, but a combo of one of those with some automation tooling might be enough.
