Help with Limine
My Limine bootloader isn’t working; every time I select an entry, it fails to mount my boot partition near the end. Does anyone know how to fix this?
I really like Limine and want to keep using it, but I may have to switch back to systemd-boot if I can’t fix this.
Have you contacted the creator of limine yet ?
No. I don’t think that I could either.
There is a Limine Matrix channel, which might also have some people who could help you out.
I just got help there and read the documentation. It works now!
Nice! Added the question tag to this topic so that it could be marked as solved. Team effort on this and then @ImInYourWalls confirming. :purple_heart:
