Fedora 45 Released
Fedora 45 was released yesterday, November 3rd. I was an early bird and I upgraded my home system (Fedora Sway Spin) to that. Upgrade was smooth, except that after the first boot it did not recognize my AMD Radeon R5 430 2GB GDDR5 Graphics Card. The monitor on the mainboard display port came up fine. I did a restart and it has been working since.
In due time I will upgrade my work laptop.
Now that you’ve had a day or two with Fedora 45, are you happy with it and is the AMD Radeon R5 430 2GB GDDR5 Graphics Card working better now or have you been forced to tinker around with it again?
No problems since. Upgrade has been steady as a rock.
Oh there was one problem though. I use gLabels to generate labels for my wife’s business. The version on Fedora 44 was 3.0. Fedora 45 upgraded to 3.4.1. gLabels 3.0 files were compressed, and when I tried to open them in 3.4.1 I received an error: “Not a supported file format.”
ChatGPT’s answer according to this bug report on Debian (I Challenge Thee) was to uncompress the file using the command gzip -dc. Once that was done it opened in 3.4.1.
Glad it went smooth. Fedora upgrades have been pretty painless for me too.
On the gLabels thing, if your wife has a bunch of old label files, you don’t have to fix them one at a time. Run this in the folder with them. It only touches files that are actually still compressed, and it backs up the originals first:
mkdir -p glabels-backup && for f in *.glabels; do if file "$f" | grep -q gzip; then cp "$f" glabels-backup/ && gzip -dc "$f" > "$f.tmp" && mv "$f.tmp" "$f" && echo "fixed $f"; fi; done
If everything opens fine afterward, you can delete the backup folder. I’d still keep a copy of the whole folder somewhere before upgrading the work laptop, since it’s for the business.
On the card not showing up on first boot: the R5 430 is an older GCN 1.0 chip, and those can load under either the older radeon driver or amdgpu. After a big upgrade the first boot sometimes trips over that. If it ever happens again, this will show what the driver complained about on the boot before:
journalctl -b -1 | grep -iE "radeon|amdgpu"
Sounds like it sorted itself out though, so no need to mess with it unless it comes back.
