Hi, @Norm24 ![]()
You wrote:
You’re most welcome!
I believe that @hydn is (probably) absolutely right when he believes that the remaining issue that you had was the change of the UUID of the ESP (EFI System Partition) - that gets mounted in /boot/efi - due to the partition having been formatted, and so updating the /etc/fstab accordingly should fix that. Did you try to do that? If so, did it work?
