Using WiFi in Kali Linux Virtual Machine on macOS
You can use WiFi in your Kali Linux virtual machine without any external devices. I have done so on my 2024 MacBook Air M3 Silicon running Kali Linux in a UTM virtual machine.
The communication problem can be solved by running an ngrok TCP tunnel inside of the virtual environment. By adding in ngrok, you can then capture TCP packets on the 802.11 frequency on the operating system and reroute them into your virtual environment.
System Architecture
The system will look a little like this:
macOS (has real WiFi)
tcpdump locks en0 to channel 11
captures live 802.11 radiotap frames
pipes to netcat
ngrok TCP tunnel (encrypted)
Kali VM (listening)
netcat writes to FIFO
tcpreplay injects into virtual wlan0
every Kali tool sees real monitor-mode traffic
Prerequisites
On macOS:
- tcpdump
- netcat (built-in)
On Kali:
- ngrok CLI (https://ngrok.com)
- Netcat (built-in)
- tcpreplay (
sudo apt install tcpreplay)
Setting Up Virtual WiFi Receiver
You can set up a virtual WiFi receiver on your Kali system. This will create a digital wlan0 channel in managed mode, allowing your virtual machine to understand that it is capturing TCP packets. It believes that it is receiving WiFi packets naturally in the same fashion that the operating system is.
Enabling Monitor Mode
You can now flip Kali into monitor mode.
Terminal Setup
Inside the Kali machine, you will set up 3 terminals.
Terminal 1: The FIFO Channel
Terminal 2: The TCP Replay Monitor
Terminal 3: The ngrok TCP Tunnel
The TCP ngrok tunnel does require extra steps during the setup, including adding rules to your config file. You can follow the instructions on the TCP endpoint docs provided by ngrok.
Capturing and Transmitting Packets
Finally, you can capture and transmit the TCP packets on your operating system
Conclusion
This will allow you to choose the application which you wish to use the data being transmitted with. Now we are able to use applications like Wireshark or airodump-ng without the purchase of any external devices for your setup.
There is a detailed README.md on the website posted in my profile. Please let me know what you think!
