Mystery - vmlinuz & initrd.img being renamed by unknown process
I have a mystery on my hands!
I am running Ubuntu MATE 22.04.5.
Many months ago, I installed a newer kernel, version 6.8.0-45-generic instead of the expected 5.15.0-177-generic.
I discovered about 6 months ago, that
vmlinuz -> vmlinuz-5.15.0-177-generic
vmlinuz.old -> vmlinuz-6.8.0-45-generic
initrd.img -> initrd.img-5.15.0-177-generic
initrd.img.old -> initrd.img-6.8.0-45-generic
Thinking that updates of that 5.* kernel improperly bumped my 6.* kernel out of its position of primacy, I intervened manually, renaming the files for what for me was logical, meaning
vmlinuz.old -> vmlinuz-5.15.0-177-generic
vmlinuz -> vmlinuz-6.8.0-45-generic
initrd.img.old -> initrd.img-5.15.0-177-generic
initrd.img -> initrd.img-6.8.0-45-generic
When I noticed the swap again 1 month ago, I did not remember doing any kernel updates, but the swap had been done again!
Once again I “repaired” the “mis-alignment” manually.
Today, going to check my kernel version, I noticed once again that the files were swapped !!!
Does anyone undestand why this is happening and what I need to do prevent it from happening again?
No, I do not have automatic updates. Those have been turned off for years!
Those symlinks are managed by update-initramfs and related kernel post installation scripts. Even with auto-updates off, something is occasionally triggering a kernel hook. ITs worth checking your apt and dpkg logs around the times you noticed the swap to see if anythng touched a linux-image package.
Also, to avoid this you can look at pinning your preferred kernel as the GRUB default so it boots correctly regardless of what the symlinks are doing.
It does boot with the proper kernel, which is 6.8.0-45-generic.
Definitely not for this last instance. So something currently configured on the OS is doing it for some reason. :frowning:
I will look into the update-initramfs. Thank you, Hayden.
