Ln Command in Linux: Hard Links vs. Symlinks
Read the full article: ln Command in Linux: Hard Links vs. Symlinks
Hard links and soft links in Linux both use the ln command but behave very differently. This practical guide explains exactly how each works, when to use which, and how to avoid the common pitfalls that catch even experienced sysadmins. continue reading.
Thanks for this! Definitely going on the reading list.
Good article :+1:
My advice is: Never use hardlinks unless you have a detailed explanation for:
  1. why you would need it
  2. why it can’t be done relatively simple in any other way.
The result is that over the years I only used hardlinks once.
It was a very special case indeed :slight_smile:
My stance is that hard links should only be used to save even the minimal bytes such save over symlinks when trying to get an image installed into firmware under extreme space constraints.
In my view, there are no Use Cases, for servers or Users that justify such hard links.
