Kvm-configurator
Hello everyone,
I’ve been working on my first Go project for a few days now.
kvm-configurator is used to configure KVM/QEMU VMs via the terminal.
This is useful for servers where you don’t have tools like virt-manager.
Looks very useful, if I didn’t have virt-maager already I’d try it out.
Made some more progress: Version 1.0.1
  • Small “progress bar” during VM creation
  • Theoretically, a boot order can now be specified, but it doesn’t work properly yet and hasn’t been fully tested
  • ISOs are now sorted by name
New weekend, new release :D
Version 1.0.6
What’s new?
KVM-TOOLS
What’s Changed
  • xml is now saved correctly in the selected path
  • small check to see if the config yaml is available
  • code optimizations
  • add support vor graphic & sound
I’m currently struggling with a TUI design. Eventually, I’ll figure out how it works :smiley:
Little update Release v1.0.7 · mrtoadie/kvm-configurator · GitHub
Now my little program is in the AUR.
can be installed via yay -S kvm-configurator
