Like the title says, it won’t connect via Virt-Manager or launch any VM’s from Virtual Manager. it tells me the connection isn’t active. so how would I activate it? This used to work.
Ah now I see, you mean the network connection right?
Can we start over?
What do you want to do? Du you want to connect via ssh to the VMs?
I want to be able to run the currently installed VMs. It claims the default connection isn’t active and throws a stack trace error:
Error starting domain: Requested operation is not valid: network ‘default’ is not active
Traceback (most recent call last):
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 67, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 101, in tmpcb
callback(*args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/libvirtobject.py”, line 57, in newfn
ret = fn(self, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/domain.py”, line 1446, in startup
self._backend.create()
File “/usr/lib/python3/dist-packages/libvirt.py”, line 1390, in create
raise libvirtError(‘virDomainCreate() failed’)
libvirt.libvirtError: Requested operation is not valid: network ‘default’ is not active
Yes It used to work, it just quit working after an update and I can’t get the dumb thing to activate for any of the shown VMs in Virt-manager.
The address shows as:
virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 9e:03:76:da:23:d3 brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global noprefixroute virbr0
valid_lft forever preferred_lft forever
8: vnet2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
link/ether 0e:8f:90:15:e3:cd brd ff:ff:ff:ff:ff:ff
9: vnet0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
link/ether 1a:fb:69:6f:9b:dd brd ff:ff:ff:ff:ff:ff
10: vnet3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
link/ether d6:2b:c5:29:6b:1b brd ff:ff:ff:ff:ff:ff
This might help you: https://linuxconfig.org/how-to-use-bridged-networking-with-libvirt-and-kvm
Well it appears I lost the “master” connection somehow. I can’t get virbr0 or default to be active @ the same time. I guess it’s off to bugzilla ![]()
Well it almost got me there, we’ll see how well Bugzilla works for this. Stupid connect still won’t activate
And now I’m using Windows to reply to this. I’ll verify I didn’t type something wrong I guess.
okay after a re-install of my OS I fixed it.
I still have no idea what broke in the first place so I’m slowly re-adding my Virtual Machines. And working on my backups so they’re better organized.
Nice to hear that it works again. But re-install is heavy…
yes it’s like killing flies with a nuke, but, the more I tried to fix it the more broke it became. ![]()
I agree with @toadie .
It is widely documented that QEMU networking can be problematic. I disable NetworkManager, install “bridge-utils” (Linux kernel bridge), and basically ignore QEMU networking.
Linux kernel bridge works great with virtio networking.
