Hey distro hoppers, this is for you ![]()
With quickemu, VMs can be created quickly and easily, just like with Docker.
quickget xubuntu 24.10
quickemu --vm xubuntu-24.10.conf
There is a matching management GUI, quickgui, for example.
Thanks for sharing this! I hadn’t looked into Quickemu before, but this looks like a solid way to spin up VMs quickly. Appreciate the tip!
Definitely something worth trying. Have you been using it for a while, or just started experimenting with it?
For a week now, everything has worked very well except for a VM with MacOS. Ubuntu derviate, Arch, Solus and Windows 11, no problems.
Running VM looks like this:
Windows 11?? Really?? I will also look this up.
I now see that How-To-Geek has a nice write up on this software.
https://www.howtogeek.com/get-windows-on-linux-in-10-minutes-with-quickemu/
