Enable citations
Currently:
[^1]
[^1]: [`example:`](https://example.com/)
…renders as:
Instead, it should render as:
[^1]
  1. example:
hi @RokeJulianLockhart
I’ve just enabled footnote markdown:
If it does not conflict with other markdown it will remain enabled. thanks!
@hydn, thanks. If you had the solutions plugin enabled, too, I’d mark your response as it!
@hydn I’d like to confirm: there is no ‘Mark as solved’ checkbox anymore.
The Mark as solved is enabled in the Linux Support category.
Thank you, accepted and understood :slight_smile:
Also it’s enabled in MATE Desktop per request. We can probably add it to some other categories like Arch Linux Debian Fedora/RHEL and Ubuntu
@hydn, one Discourse instance that I utilise enables it everywhere:
That even includes DMs. It’s very helpful. However, perhaps this would be worth splitting into another topic.
Thanks @RokeJulianLockhart
This post was really helpful!:
That’s a good compromise and I’ve gone ahead and renamed the existing q-and-a tag to: question and enabled the solved feature on that tag.
This seems to have the most global effect without having to enable it on every single topic.
