Since the latest update, ubuntu doesn’t see my Bluetooth device. Has anybody experienced this. AI hasn’t been able to fix it!
I had a problem with stability of WiFi after Ubuntu update not that long ago. The problem was bypassed by booting previous kernel. Fortunately, the next kernel update fixed the problem.
I had an issue with a kernel update that was causing a constant reboot failure but didn’t effect the Bluetooth. I reverted to an earlier kernel and the problem was solved. Recently there was another kernel update that had no effect on booting but killed the Bluetooth! I don’t think that I can go back any further than the one kernel update to solve the Bluetooth issue and not have the reboot problem reappear.
I had an issue twice with broadcomm WIFI not working after a kernel update. I did the same thing, reverted to the old kernel and just waited for the next kernel update.
I have also had bluetooth just quit working, Deleting the connection and making a new connection worked for that.
