Hi
Any of you using Peazip compared to any other alternative apps ?
W
Peazip here. Just wish there was a ppa for for it so that I don’t have to manually download when there’s a new version.
PeaZip really is the gold standard in terms of features. But if you’re on KDE, default Ark is usually enough, it’s what I end up using most of the time.
A flatpack version will not update itself ?
There is a .deb you can get from their web site: Download PeaZip archive manager for Linux x86_64
W
Peazip has worked well for me, met all my needs after Engrampa had its 7 zip problems.
I have never heard of peazip.
Thanks for sharing! I’ve been using gzip and sometimes 7-zip.
Will be checking this out. ![]()
I’m use 7z and unzip
7z x archive.whatever
Sorry not fan of any gui archiver.
No need to apologize for what you prefer. Some people want a GUI and some like me need a GUI. That is what makes Linux great, you have a choice to use the method you prefer.
Not big into Flatpaks, rather just stick to .debs when I can. I check the Peazip site every few weeks to see if there’s a new version and just download and install but having a ppa would make it easier.
Same here as I’m still on UM 24.04.
If I remember correctly the issue with Engrampa was fixed in Mate 1.28 but I’m not keen on upgrading my daily driver to 26.04 at this point. Peazip does the job just fine.
Norm
Your comment made me curious
and I found this:
https://linuxcapable.com/how-to-install-peazip-on-ubuntu-linux/
but I have no idea about actual XtraDeb PPA reliability. Never used that.
W
Xtradeb can cause more problems than it solves. It will update anything on your machine that’s in its database and cause all kinds of issues/conflicts.
I see… good to know.
W
