The dangers of prepending $PATH
This might be an interesting read w.r.t. PATH hijacking:
check your ‘.profile’:
grep PATH .profile
I mostly follow the advice here, but I’ve had /usr/local/bin first in my path; that may not be horrible because elevated privileges are needed to run there, but I followed the advice here; switched it on one system and I am in the process of changing it in other setups too. The remainder of my path selections, particularly the personal path entries ARE at the end of my path, so that’s better.
Indeed! Thanks for sharing this.
