I am trying to install Zorin. My old laptop has a Win10 system and I used a partition tool to create a Linux volume. The installation process is stuck at the part when you choose where to install Zorin.
What requirements must the destination have to accept the install? This is what I expected to use:
Dev: /Dev/SDA7
Type: Ext4
Used: 16384MB
System: Linux 20.2UMA(20.2)
Is the formatting wrong?
