Thanks for the clarity. Why would software running Rust generate a lot of heat; does Rust REQUIRE recent generation hardware to run “efficiently”?Thanks for the clarity. Why would software running Rust generate a lot of heat; does Rust REQUIRE recent generation hardware to run “efficiently”
I read
“speed” also generates heat
in your earlier post, and I got the idea you were concerned about heat. Seems like I misunderstood. Regarding “you might have a problem given complaints about compile times” in my last post, I was simply thinking if the compilation takes a really long time, then the pc might generate heat.
Importantly, my thought about efficiency/speed is entirely about how Rust can be highly optimized, which implies fewer operations, which implies faster code. Sometimes rustc generates really fast code with zero programmer effort, but when it doesn’t, rustc offers numerous ways (asm, SIMD, …) for a skilled programmer to manually optimize. (I am not skilled)
And
I’m pretty sure the answer is no as far as running compiled code, but the answer is maybe as far as compilation goes. Like I said, I haven’t had an issue compiling, but I’ve read and heard plenty of complaints. I think people have problems when they use many packages (libraries), which I don’t do (don’t need to).
Maybe it’ll help with a few of my questions; I’ll let you know if I spot anything of interest.
I found this comment for starters: “Go remains valued for its simplicity, concurrency model, and strength in cloud and backend development, while Rust continues to attract developers looking for performance, memory safety, and greater control.”
I’ll look into this and more later on. Thanks for sharing with us and following up on my questions.
HERE is something else I found as I scrolled further down the article:
Rust’s Low-level memory management:
Rust provides control over memory allocation without a garbage collector, which means it can operate closer to the hardware and manipulate memory with high precision. This is beneficial for systems programming where low latency and high throughput are crucial. For instance, a benchmark by benchmarks game shows that Rust implementations tend to have lower memory use and are often faster in computation-heavy tasks compared to Go.
Strengths in Go’s concurrent programming
Go’s built-in support for concurrency allows developers to easily implement scalable server-side applications. Its simplicity in managing multiple threads of execution without the overhead typical of more verbose threading models is a significant advantage in web services and cloud applications.
Trade-offs: Although Go provides substantial ease of use and satisfactory performance for web servers and simpler backend services, it may not reach the performance extremities required in low-level system programming or where granular control over memory and processing is essential, areas where Rust excels.
Rust’s steep learning curve
Rust is known for its stringent compiler and its unique approach to memory management through ownership and borrowing concepts. While these features contribute significantly to Rust’s performance and safety guarantees, they also steepen the learning curve. New programmers might find Rust challenging as they need to adhere strictly to its rules to even compile the code, a stark contrast to more lenient languages. However, once mastered, these same features make Rust exceedingly reliable and secure, particularly in concurrent and system-level programming contexts.
Rust vs Go: Concurrency and multithreading
Both Rust and Go provide robust solutions for handling concurrency, each through distinct approaches and constructs. As multithreading becomes increasingly crucial in modern applications, understanding how each language facilitates concurrent operations, alongside their respective strengths and weaknesses, is vital for developers.
