Pacman I/O tweaks for older spinning disks
I’ve been thinking about this since @Halano post about pacman’s pros and cons. He’s right, all those open() and close() calls in /var/lib/pacman/local are rough on a spinning disk.
For those on an HDD, you can try the following:
Keep the cache under control. /var/cache/pacman/pkg grows forever by default. Use paccache -rk3 to keep the last three versions and clear the rest. Less clutter, fewer filesystem hits. See: [SOLVED] Question about cleaning the package cache / Newbie Corner / Arch Linux Forums
On ext4, I’m not sure what the default is now, but mount with noatime. Pacman reads a ton of small files and atime updates turn that into extra writes.
Also see tips for general disk I/O reduction here:
Also found these related discussions on eatmydata with pacman and deadline scheduler:
https://bbs.archlinux.org/viewtopic.php?id=80377
https://bbs.archlinux.org/viewtopic.php?id=263637
