Quick Tips for a more stable Arch Linux experience
Read the full article: Quick Tips for a more stable Arch Linux experience
We have revised and updated this article to ensure its relevance and accuracy in 2024. This updated guide is tailored to help you harness a most stable Arch Linux experience. The existence of this article does not indicate that Arch Linux is unstable. It’s not, far from it. But for new users, there are certain… continue reading.
I keep being put off by the lengthy set up time with Arch. The stability issues were never a major hindrance for me but I like knowing there is a solution. Would you happen to have a guide on setting up Arch to make it less time consuming?
Hi Rexx. Thanks for asking! Yes, you can use the Archinstaller. GitHub - archlinux/archinstall: Arch Linux installer - guided, templates etc.
Here’s a great video guide:
Hello, some updates and corrections
i686/x86-64 general-purpose GNU/Linux
It is x86_64 only since late 2017
Install Skype with pacman -S skype
This has never been a valid command, skype has never been in the official repository and pacman don’t deal with AUR pkgbuilds
The skype pkgbuild no longer exist, there is skypeforlinux-stable-bin now AUR (en) - skypeforlinux-stable-bin
@FabioLolix Thanks so much! This article was first published on November 19th, 2014, so I really appreciate this type of feedback to keep the advice current.
Note Skype used to be in the multilib repo.
So it used to be that you just allowed the multilib repo by uncommenting it:
sudo vi /etc/pacman.conf
Then just update pacman
sudo pacman -Syu
and install Skype
sudo pacman -S skype
Making those updates to the article now.
P.S. Welcome to the forums! :handshake:
