Linux Server Health Checks: 10 Metrics Every Sysadmin Should Monitor
Read the full article: Linux Server Health Checks: 10 Metrics Every Sysadmin Should Monitor
Servers give you warnings before they fail. Most sysadmins performing Linux server monitoring miss them because they’re watching the wrong numbers. The metrics that actually matter are one level deeper: iowait instead of CPU percentage, active swap paging instead of memory usage, inode counts instead of just disk space. If you’re not tracking them, you’re… continue reading.
