Read the full article: 2100 HDD0 initialization error 1 | LinuxBlog.io
I’ve noticed an issue on a few IBM/Lenovo Thinkpads. When you install an SSD drive, a reboot or restart from the OS does not work. When you reboot, instead opening the boot partition, it throws this error: 2100 HDD0 initialization error 1 Other than avoiding reboot and using shutdown instead, the only solution I’ve found…
