It’s a collection of unrelated software mashed up together, yet without much meaningful integration.
Logs are stored in a binary format of custom specification:
- It is great for filtering,
joyrnalctlis much better than a long chain ofgrep | sed | cut | whatever, and uses internal tags rather than string regex. - It is useful to just browse around through logs, but when the system crashes? File is corrupted.
- It, despite being a great concept, fails right where it’s needed the most.
Reinventing /home
- Great, but why a daemon? Why not call the helper
systemd-homeworkvia PAM itself or whatever? - After so much for “portable across systems”, how exactly is that achieved? It tags the machine-id and refuses to accept the new image on other systems, unless ugly hacks are followed.
- It slows down the startup and shutdown, for some reason… (even a cobbled-up bash script does the process faster; It’s just flush-to-disk,
sync, unmount, un-unlock/lock, un-(device-)map, reflush, exit)
inetd in PID-1
Well, this has it’s own serious implications. Mainly, it now requires heavy libraries to be pulled in by the PID-1 binary.
poweroff doesn’t work if an openssl library is missing/corrupted…
Well, this is true, I have experienced this. The boot failure next day because I forcefully powered-off, is also caused by this.
Please, let the core system components be free of all this.
Whatever is chase() in libsystemd
systemd-tmpfiles fails to run because some mount is not they way systemd likes (Like in a chroot + unshare).
AND udevd, and many other things
What else?
I like systemd, it’s great. But the issues…
