Should I stay on Arch or try Fedora?
Which spin of Fedora are you using? I am currently on Sway.
I think Debian has the most packages. Plenty of the AUR packages are converted from .deb files which is why the AUR is so huge. So if an app is coming from Windows the second OS they would convert to is deb and like @ricky89 alluded to, Ubuntu is huge.
I am not super fan of tiling manager; early this year I tried a couple of them and I was not satisfied enough: or you love them or you absolutley hate them (:
You can read what I really think about tiling manager here:
After half year I did not change my preferences, I choosed my beloved XFCE spin.
I’m a bit surprised at the allegiance to Fedora and Red Hat. Sure, if you work with RHEL on the job then using Fedora at home makes sense. Otherwise though, these are the guys that hoisted systemd on so many people. Even Debian fell for it; the distributions I use most don’t use systemd; in fact, I’ve checked out many init other than sysVinit and systemd; I’ve been mostly using runit as my init, but I’ve worked with dinit, s6 (and an Obarun variation of s6 called s6-66 or just 66, plus OpenRC). Not too much practical difference. The “offensive” things about systemD are that it’s not just an init; those who don’t know, don’t care about init are fine with systemD handling so much, but those who understand it object, plus they object to the huge corporation behind it - (IBM) and the guys who developed systemd have worked for IBM and Microsoft, so SOME Linux zealots avoid systemd for that reason alone. I don’t avoid it for that reason; I haven’t had problems with it on Debian, but I still prefer an init that starts process 1, then assists the kernel in process init and that is it. Seems cleaner to me.
It’s true that systemd goes far beyond just being an init, and for users who prefer a minimal, modular setup, that can feel like overreach. That said, I can understand why Fedora and systemd have their fans. For a lot of folks, it just works and stays out of the way. It really depends on how deep someone wants to get into process management.
Beyond the RHEL pipeline, many users choose Fedora for its cutting-edge kernels and up-to-date desktop environments, its upstream influence on core Linux projects, and its strong SELinux defaults. The DNF tooling and frequent release cadence mean you get the latest software without sacrificing stability, and the Fedora community is great at catching regressions early.
All of that adds up to a distro that appeals to hobbyists, developers, and sysadmins alike. Even if they’re not working with RHEL at their day job.
As I commented elsewhere it may be more convenient. I’m not looking for a Windows wannabe. I’m looking for clean handling, especially for something as critical as process creation.
To me it shouldn’t be a huge module. I looked at the source code of one init. Though it wasn’t easy to understand because of code address logic, it was small enough to read in a single setting.
Had I wanted to research every line of code it would be possible in a day, maybe even an afternoon of studying.
Try that with systemd. I’d have headaches for a week or a month!
I get the appeal of a small, auditable init, being able to read the entire source in an afternoon is a strong argument for transparency and simplicity.
But clean handling doesn’t always have to mean minimal. It can also mean consistent behavior, well-integrated tooling, and fewer moving parts to manually stitch together.
The reason systemd has a larger codebase is because it does more. It’s not just an init system. It also takes on service supervision, logging, network management, timers, cgroup handling, and more.
Most smaller inits lean on external tools for all that, which keeps their own code light but shifts the complexity elsewhere.
So while I don’t mind exploring other init systems, I don’t see systemd’s size as a flaw in itself. It’s a tradeoff, more features and tighter integration versus minimal scope and modularity.
Both approaches have their place depending on what you’re trying to build or maintain. That’s the beauty about Linux and even hardware as per my other reply regarding my dim view of Ideapad vs. Thinkpad.
I have been using Fedora for a few months now and one of the key reasons that I see where myself and others have made the switch is time. We want something vanilla, that works out of the box without too much tinkering. Also while bleeding edge software is not a necessity we prefer a distro that is closer to the edge than far behind. So once systemd is not in the way of day to day operations, most of us won’t mind. Again if we had the time, we would of course tinker to gain performance and simplicity, but alas time is not with us.
I appreciate your viewpoint and I also believe in diverse solutions, including this one that I happen to disagree with. Done right, I suppose it’s a plausible alternative. After all, a lot of the GNU stuff, including my long favorite GNU Emacs does a lot more than the simple editing of text. The main reason I’d rather not have such capability in the init is that the direct handling and initiation of processes, at least to me, deserves to be isolated. If something one step or one layer past the process initiation handled most or all of the system management that would be less disagreeable, and chances are that systemD does divide it up in that manner; being a binary, and I haven’t had the opportunity to look at the source, it’s difficult to know.
Either way, I DO respect other ways of doing things; that doesn’t mean that I’ll alter my personal preferences. It’s the same with free versus commercial stuff: I definitely believe in having both available so that choices can be made, yet my own choice is to stick with the light stuff.
In the case of the init options, I found it fascinating to get an actual look at one or two of the code options. While I didn’t immediately understand every line of the code, I was able to understand the flow of the init process and it was fascinating.
Just my .02. I was a long time Arch derivative user. In fact I stopped distro hopping for years after landing on Manjaro. Sometime in the last year I moved on to Garuda and CachyOS when I had separate gaming and home rigs (eventually combined the two). I just switched to Fedora this week. Why? I’d forgotten over all that time that a solid non-breaking Arch based distro is not the same thing as a solid desktop.
I use my desktop now for a business and I just wanted to slow down the updates and get back to that ready to go out of the box feel vs tinkering. No Manjaro, CachyOS etc. aren’t Arch level of tinkering but sometimes you might need to install something from the AUR and it doesn’t work and other things of that nature. Also speaking of the AUR that mishap with the bad Chrome package spooked me into looking to get back to repos, debs/rpms from the vendor and Flatpaks or Snaps.
So I decided to do a little research and since Bazzite and Nobara were based on Fedora I checked out it’s gaming performance. It looked to be just a hair behind CachyOS and after doing some minimal testing (Cyberpunk benchmark) it seems to do very well on my hardware. The balance of a little more stability while still having access to newer packages plus Fedora’s rather dev centric positioning has tipped me over to Fedora for now. And it’s funny because Fedora used to always be the distro I’d leave the quickest but it appears they’ve really progressed (along with KDE) over all of these years.
What about Endeavour OS?
If a person is used to Arch, to me that’s the reliable way to use an Arch-based system. Login and either type in yay at a command prompt or if you can’t be bothered with that, their Welcome Center has easy buttons to click.
I realize that Fedora has become easy but so have both Cachy OS and Endeavour OS.
There really aren’t too many difficult distributions remaining. Most of them offer point and click interfaces that make management of the distribution a non factor.
