Looking for feedback and contributions, to what would be a shared tool, to generate the list of packages, installed by the User, after the basic Distro installation.
Intent is to be able to either
duplicate the same package set on another host (or a host rebuilt from scratch), or
present that set of packages as a checklist table for choosing to install only a subset of the packages currently installed (a future YAD-based project), again on another host or a host rebuilt from scratch.
Current state of the script is to
identify the manually installed files,
sort the packages by age as determined by the corresponding *.list file
identify packages not having an *.list file and determine if those have dependent packages, with a view of determining whether they are worthwhile retaining as part of the replication/rebuild set
Are there any recommendations regarding a better approach to tackling the above problem?
Session log (so far):
# ./PKGS__Report_PostInstall.sh
List of Manually Installed Packages [659]:
-rw-r--r-- 1 root root 8801 May 2 22:18 PKGS__Report_PostInstall.manual.txt
The following contains the list of packages [593] sorted by oldest installation:
-rw-r--r-- 1 root root 29202 May 2 22:18 PKGS__Report_PostInstall.stat.txt
The following packages did not have a corresponding '*.list' file to determine installation date:
-rw-r--r-- 1 root root 4600 May 2 22:18 PKGS__Report_PostInstall.nolist.txt
Evaluating zlib1g-dev ... DEPENDANTS
Evaluating tk-table ... DEPENDANTS
Evaluating tk-html1 ... DEPENDANTS
Evaluating tk-dev ... DEPENDANTS
Evaluating tkblt-dev ... DEPENDANTS
Evaluating tkblt ... DEPENDANTS
Evaluating tk8.6-dev ... DEPENDANTS
Evaluating tcl-memchan-dev ... DEPENDANTS
Evaluating tcl-memchan ... DEPENDANTS
Evaluating tcllib-critcl ... DEPENDANTS
Evaluating tcl-dev ... DEPENDANTS
Evaluating tcl8.6-dev ... DEPENDANTS
Evaluating qtbase5-dev ... DEPENDANTS
Evaluating qml-module-qtwebkit ... DEPENDANTS
Evaluating openjdk-17-jdk ... DEPENDANTS
Evaluating openjdk-11-jdk ... DEPENDANTS
Evaluating mesa-common-dev ... DEPENDANTS
Evaluating libxrdapputils2 ... DEPENDANTS
Evaluating libxrandr-dev ... DEPENDANTS
Evaluating libxinerama-dev ... DEPENDANTS
Evaluating libxine2-ffmpeg ... DEPENDANTS
Evaluating libxi-dev ... DEPENDANTS
Evaluating libxcursor-dev ... DEPENDANTS
Evaluating libwebp-dev ... DEPENDANTS
Evaluating libwebkitgtk-6.0-4 ... DEPENDANTS
Evaluating libupower-glib-dev ... DEPENDANTS
Evaluating libssl-dev ... DEPENDANTS
Evaluating libssl3 ... DEPENDANTS
Evaluating libsqlite3-dev ... DEPENDANTS
Evaluating libqt5webkit5-dev ... DEPENDANTS
Evaluating libqt5opengl5-dev ... DEPENDANTS
Evaluating libpoppler-dev ... DEPENDANTS
Evaluating libpng-dev ... DEPENDANTS
Evaluating libosmesa6 ... DEPENDANTS
Evaluating libopencsg1-dbg ... DEPENDANTS
Evaluating libmpg123-dev ... DEPENDANTS
Evaluating libjpeg62 ... DEPENDANTS
Evaluating libhwloc-contrib-plugins ... DEPENDANTS
Evaluating libgtkmm-3.0-dev ... DEPENDANTS
Evaluating libgtk-4-dev ... DEPENDANTS
Evaluating libgtk2.0-dev ... DEPENDANTS
Evaluating libglu1-mesa-dev ... DEPENDANTS
Evaluating libglibmm-2.4-dev ... DEPENDANTS
Evaluating libglfw3-dev ... DEPENDANTS
Evaluating libglew-dev ... DEPENDANTS
Evaluating libglade2-0 ... DEPENDANTS
Evaluating libgl1-mesa-dev ... DEPENDANTS
Evaluating libfontconfig1-dev ... DEPENDANTS
Evaluating libfftw3-dev ... DEPENDANTS
Evaluating libexpat1-dev ... DEPENDANTS
Evaluating libegl1-mesa ... DEPENDANTS
Evaluating libdvdcss-dev ... DEPENDANTS
Evaluating libdvdcss2 ... DEPENDANTS
Evaluating libcairo-script-interpreter2 ... DEPENDANTS
Evaluating libcairo2-dev ... DEPENDANTS
Evaluating libboost-dev ... DEPENDANTS
Evaluating libbluray-dev ... DEPENDANTS
Evaluating libbdplus-dev ... DEPENDANTS
Evaluating libavcodec-extra ... DEPENDANTS
Evaluating libavcodec-dev ... DEPENDANTS
Evaluating libao-dev ... DEPENDANTS
Evaluating gtk3-engines-unico ... DEPENDANTS
Evaluating gstreamer1.0-plugins-bad ... DEPENDANTS
Evaluating gir1.2-evince-3.0 ... DEPENDANTS
Evaluating freeglut3-dev ... DEPENDANTS
Evaluating caja-extension-fma ... DEPENDANTS
Coud some of these that have ‘DEPENDANTS’ be superfluous, given that the is no corresponding *.list file?
Script: PKGS__Report_PostInstall.sh
#!/bin/bash
dbg=0
### Script Intended To Identify All Post-Distro User-Installed Packages
### NOTICE - Work-in-progress - Looking for feedback, additions, enhancements
progress=0
now=$( date '+%Y%m%d_%H%M%S' )
work=$( basename "${0}" ".sh" ).work.tmp ; rm -f "${work}"
marked=$( basename "${0}" ".sh" ).manual.txt ; rm -f "${marked}"
fTemps=$( basename "${0}" ".sh" ).temp.txt ; rm -f "${fTemps}"
fDates=$( basename "${0}" ".sh" ).stat.txt ; rm -f "${fDates}"
fPackg=$( basename "${0}" ".sh" ).packgs.txt ; rm -f "${fPackg}"
fMssng=$( basename "${0}" ".sh" ).nolist.txt ; rm -f "${fMssng}"
report=$( basename "${0}" ".sh" ).${now}.txt ; rm -f "${report}"
### Get Manually Installed Packages
comm -23 <(apt-mark showmanual | sort) <(gzip -dc /var/log/installer/initial-status.gz | sed -n 's/^Package: //p' | sort) >"${marked}"
numMrk=$( wc -l "${marked}" | awk '{ print $1 }' )
echo -e "\n List of Manually Installed Packages [${numMrk}]:\n"
ls -l "${marked}" | awk '{ printf("\t%s\n", $0 ) ; }'
### Determine Installation Date of Packages
# filename perms user group size mods status filetype
#result=`/usr/bin/stat --format "%n|%A|%U|%G|%s|%Y|%Z|%F" "${fNam}" `
tac "${marked}" |
while read line
do
testor=$( grep "Package: ${line}"'$' /var/lib/dpkg/status )
if [ -n "${testor}" ]
then
list="/var/lib/dpkg/info/${line}.list"
if [ -s "${list}" ]
then
/usr/bin/stat --format "%Y|%n|" "${list}"
echo "${testor}" >>"${fPackg}"
else
echo "${testor}|MISSING|${list}" >>"${fPackg}"
fi
fi
done | {
if [ ${progress} -eq 1 ]
then
awk 'BEGIN{
cnt=49 ;
printf("%49s", "" ) | "cat 1>&2" ;
print $0 ;
cnt++ ;
if( cnt == 50 ){
printf(" | %s\n", $0 ) | "cat 1>&2" ;
cnt=0 ;
}else{
printf(".") | "cat 1>&2" ;
}END{
if( cnt != 0 ){
fmt=sprintf("%s%s%s%s", "%", 49-cnt, "s", " | %s\n" ) ;
printf( fmt, "", $0 ) | "cat 1>&2" ;
else
cat
fi
}>"${fTemps}"
### Sort Packages by Oldest First
sort -t "|" --key=1.1,2.0 "${fTemps}" > "${fDates}"
numAge=$( wc -l "${fDates}" | awk '{ print $1 }' )
echo -e "\n The following contains the list of packages [${numAge}] sorted by oldest installation:\n"
ls -l "${fDates}" | awk '{ printf("\t%s\n", $0 ) ; }'
#echo ""
#head "${fDates}"
if [ ${numAge} -ne ${numMrk} ]
then
echo -e "\n The following packages did not have a corresponding '*.list' file to determine installation date:\n"
grep '|MISSING|' "${fPackg}" >"${fMssng}" #| awk '{ printf("\t | %s\n", $0 ) ; }'
ls -l "${fMssng}" | awk '{ printf("\t%s\n", $0 ) ; }'
fi
### Identify Dependants for Packages Having No List
### No Dependants Suggests Packages Are Optional and Retention Should Be Confirmed
### Before Including in List For Host Installation Replication
boldON="\033[1m"
boldOFF="\033[0m"
greenON="\033[92;1m"
greenOFF="\033[0m"
yellowON="\033[93;1m"
yellowOFF="\033[0m"
redON="\033[91;1m"
redOFF="\033[0m"
orangeON="\033[33;1m"
orangeOFF="\033[0m"
pNameWidth=$( cut -f1 -d\| "${fMssng}" | cut -f2 -d\: | sed 's+^\ ++' | while read line ; do echo "${line}" | wc -c ; done | sort -nr | head -1 | awk '{ print $1 }' )
test ${dbg} -eq 1 && echo $pNameWidth
pWidth=$( expr ${pNameWidth} + 18 )
test ${dbg} -eq 1 && echo $pWidth
fmtStr="\t %-${pWidth}s"
test ${dbg} -eq 1 && echo "'${fmtStr}'"
echo " Evaluating 'no list file' packages ..."
for package in $( cut -f1 -d\| "${fMssng}" | cut -f2 -d\: | sed 's+^\ ++' )
do
printf "${fmtStr}" "Evaluating ${package} ... "
rm -f "${work}"
apt-rdepends -r --state-follow=Installed --state-show=Installed "${package}" >"${work}" 2>>/dev/null
if [ -s "${work}" ]
then
echo -e "${boldON}${greenON}DEPENDANTS${greenOFF}"
else
echo -e "${boldON}${redON}NO_DEPENDANTS${redOFF}"
fi
done
echo "\n\n
FUTURES:
* interractive logic to selectively purge packages identified as 'no list' if also 'NO_DEPENDANTS'
* consolidate list of package names for host 'installation replication'
\n"
exit 0
