Newbies with Questions? ...Ask away!
From what I can tell, Zorin OS might not be suited for this kind of setup. Zorin is like a fully ready to go environment and this looks like a “linux rice” which basically means, the creator probably built this from the ground up on a minimal linux installation.
I would say you will want to switch distributions to get this going. From a quick google and look at the repo, the creator may be building and testing these themes on Arch but they also suggest Fedora has fairly good compatability.
I totally get Hyprland, it’s part and parcel of Omarchy (an Arch Linux) that I really enjoy using. I really like the clean looks of tiles and especially, thanks to your link, the linux-antiquity theme, it definitely shows the degree of possible customisations out there.
I have never used Zorin but it appears to be based on Ubuntu, which I have never seen as a ricer’s paradise, and I am sure @Powder is right in his reply to you.
Also, since you have not been using Zorin long, you could try Omarchy, but not before you have done some research! At least watch this Omarchy YouTube – until the very end. I have to say that from my own experience I agree with it in its entirety. Also read this overview of Linux distros with hyprland.
Take everything with a pinch of salt until the world has run out of the stuff.
Oh, and BTW, Omarchy will encrypt your disk so make sure you backup ALL your files, bookmarks, cookies(?) etc. before installing.
Welcome to the community @KRISHNAKUMAR, awsome to have you join us! :handshake:
Hi and welcome, @KRISHNAKUMAR ! :waving_hand:
That depends…
  • TkInter (Tcl/Tk) for Python is excellent choice for simple and quick GUI wrappers. Works for Linux and Windows.
  • GTK is native choice for Gnome DE. There are GTK Python bindings. To have GTK on Windows one has to install specific flavour of MSYS development environment.
  • QT is native choice for KDE desktop environment. More than that, it is truly multiplatform. There are QT Python bindings.
  • WxWidgets work on every platform incl. GTK, QT and Windows. There are Python bindings
Welcome, Claudio!
The key to mastering IT is to know specifically what you want to get out of it, technically (i.e. Blood Pressure), then deciding if what you want is static snapshots or continuous trending, before deciding on how best to present or visualize the outputs.
Once you understand what you want, and how you want it, only then should you start “picking at” various GUIs to determine which best suits your intended context and “use cases”.
Eugene gave you a good overview of the GUIs most frequently used/encountered in packages available in Linux.
What are the Top Ten GUIs/APIs on Linux ?
I entered the following search string in Google:
linux which are the top 10 GUI APIs which are most frequently used
Google AI response:
The top 10 Graphical User Interface (GUI) APIs and frameworks most frequently used on Linux include Qt, GTK, and modern cross-platform web or language-specific wrappers. These tools power the most popular desktop environments (like GNOME and KDE) and everyday Linux applications. [1, 2, 3, 4, 5]
The most common ones used across the Linux desktop ecosystem are listed below and ranked by their overall usage, developer adoption, and historical significance:
  • GTK,
  • Qt,
  • Electron,
  • wxWidgets,
  • Tkinter / Tk,
  • JavaFX / Swing,
  • FLTK,
  • ImGui,
  • Kivy, and
  • libwayland-client / Xlib.
On Linux, the GUI architecture is unique because graphical interfaces are separate from the core operating system kernel. Apps rely on lower-level display server APIs (like Wayland or X11) or higher-level widget toolkits built on top of them. [1]
Which are the most used by commercial developers ?
Search string:
linux which are the top GUI APIs most frequently used for commercial software intended for Linux
AI Summary
The top GUI APIs and frameworks frequently used for commercial Linux software include Qt (the industry standard for heavy-duty professional apps), GTK (the native choice for GNOME environments), and wxWidgets (for native look and feel). Additionally, Electron and Web Technologies are heavily used for modern cross-platform commercial applications. [1, 2, 3, 4, 5]
1. Qt (C++, Python, QML)
Qt is the dominant cross-platform framework for complex, high-performance commercial software on Linux (used by Adobe, Autodesk, and VLC). It allows native hardware acceleration and rich UI design. [1, 2, 3, 4, 5]
2. GTK (C, Python, Rust, JavaScript)
GTK is the backbone of the GNOME desktop environment and deeply integrated into the Linux ecosystem. It is best suited for apps that need to naturally adhere to Linux system themes and accessibility features. [1, 2, 3]
3. wxWidgets (C++, Python)
wxWidgets provides a truly native look and feel across Linux, Windows, and macOS. Instead of emulating widgets, it uses the platform’s native API, saving resources and ensuring users feel at home. [1, 2, 3]
4. Electron & Web Tech (JavaScript, TypeScript)
Many modern commercial desktop apps (like VS Code, Discord, and Slack) use Electron to wrap web applications into standalone Linux binaries. [1, 2]
5. Flutter for Desktop (Dart)
Flutter has gained significant traction for building highly-branded, animated desktop UIs from a single codebase. [1]
Hi @KRISHNAKUMAR Welcome to this forum. I hope you will feel very welcome. Parrot OS is deigned for penetration testing among other things. Do you work in that area? (You are under no obligation to answer, I’m just nosey and almost everyone gets asked nosey questions by me.)
Roger
Hi @Sanjana_Rathnayake I have an MSI PC with NVIDIA RTX A2000 12GB (not very high-end) but I had no difficulty installing Arch Linux (I use Endeavouros). Obviously Ubuntu is a Debian distro so I’m surprised there’s much difference between the two in terms of hardware compatibility. You might need to tweak the BIOS to get the most out of your box if you are having resource issues. Have you tried BTOP or HTOP to see what’s hogging your resources?
Thanks for the suggestion. I actually haven’t tried changing any BIOS settings yet because I wasn’t sure which settings would be safe to modify.
Sorry for the late reply. Good to play safe with the BIOS settings. But I am still curious about your resource issues. Linux has never given me any resource issues, so I’m wondering whether there’s something else going on. Could you share the output of fastfetch ?
BTW: This is a useful site for commands that tell you about your hardware: Linux Hardware Information
Thanks very much for sharing that resource! :fire:
This issue has actually been around since I was using pop os. :smiley: I had it set up in a dual-boot with windows, and one day I accidentally deleted the pop os partition from windows, so the os was gone. :grinning_face_with_smiling_eyes::man_facepalming:
Thanks again! I’ll try that command next time and give you an update
@KRISHNAKUMAR Welcome to our community!
Regarding “Good GUIs”, I agree with @ugnvs, especially regarding Tkinter; I’ve taken advantage of Tkinter many times in my work and tinkering.
Regarding the order of installation/update when both Windows and Linux are involved, yes, as @ericmarceau has indicated, doing Windows first is best, but suppose you don’t? Are there ways to get the Linux image working properly? IF you have a live, removable media source for the Linux distribution, several of them have boot recovery options that can be used to correct a boot loader issue, and if it’s BADLY messed up, having that recovery image (or backup image) can correct or repair those kinds of errors, though doing as Eric suggests will spare you of those activities. On the other hand, those of you who REALLY ENJOY fixing broken things may relish the opportunity to figure out and repair what you’ve messed up when dealing with both Windows and Linux; in that case, removable live media, both for booting and for backup and recovery are your best friends for both planned and unplanned problems, whether you have one setup or several different operating systems installed.
i am very new what distro should i use if i want to have easy setup and a lot of customization?
Welcome to the community @heil0s, thanks for joining us! :+1:
Hi and welcome to the community!
This question depends on a lot of factors, but I think the most important question is, what is your experience with Linux so far? Have you used it before?
Generally, my recommendation for someone starting out with Linux would be Linux Mint. It’s a solid distribution with plenty of graphical interfaces to help the user out. It has a stable base and wide application support. It also offers plenty customisation.
But in the end, it depends on your specific use case. What is your experience so far, and are there any particular things you’re looking for?
@heil0s two of the requirements you mentioned are 2 of the questions on distrofighter.com:
Give it a try the top 3 recommendations are usually spot on.
So guessing your other 6 answers (so ~ 1500 ways to get wrong lol) the top result for you was:
Linux Mint with either Cinnamon, MATE, or Xfce.
Welcome to our community! You are welcome to share your journey with us. :penguin:
As a Linux novice (tried about 4 different distros), I also recommend Linux Mint. It works great on my 2012 Macbook Air! And welcome to the community!
Hey, I’ve been back and forth with Linux over the years. Most of the time compatibility issues had me go back to windows. I’ve been using Zorin for about 3 months now, I don’t see me going back to windows.
For my question, I’m installing Ubuntu now in a second hard drive for dual boot, trying it out. Can one OS use files from the other? Or do I need to make a partition and save files there so I can access them from both OSs? What’s the most optimal way to go about that?
Welcome to the community @mpage85, good to have you here! :+1:
Welcome, @mpage85!
If wanting to have both OSs on the same box, 2 separate physical disks is best, because Windows tampers with the GRUB which messes up booting for Linux, with or without secure boot. Recommended configuration
  • Disk 1 - Pure Windows (no GRUB)
  • Disk 2 - Pure Linux (with GRUB controlling and offering OS selection menu for booting)
  • Always set BIOS disk priority for Disk 2 to ensure it is the startup boot machine until the GRUB menu comes up, which can then gracefully restart with Windows upon selection there.
This question has two components:
  • disk storage format (OS-dictated), and
  • file storage format (App-dictated).
Nowadays, OSs seem to be “mostly” cross-compatible regarding disk formats, but the BIG issue is the age of hardware (firmware-dictated range of format recognition) and age of OS on legacy hardware (software limitations for disk format recognition and connectivity compatibility).
ONLY in the extreme, you might be forced to do that, but that would have to be some “weird” hardware limitation such that it could not be upgraded to something more current (not necessarily the latest and greatest) in order to make the sharing less of a conscious effort.
