"MySQL server has gone away" error - Solution(s)
Read the full article: “MySQL server has gone away” error – Solution(s)
The MySQL server has gone away error, which means that the MySQL server (mysqld) timed out and closed the connection. By default, MySQL will close connections after eight hours (28800 seconds) if nothing happens. However, in some cases, your web host, DBA, or app developer may have decreased this timeout setting, as discussed below. MySQL… continue reading.
This saved us with intermittent issues. Thanks for sharing this!
This article has been updated.
