How to Gzip a Directory Using Linux Command Line
Originally published at: How to Gzip a Directory Using Linux Command Line | LinuxBlog.io
Efficiently managing files and directories is a fundamental task in computing. It’s crucial for keeping our data organized, optimizing storage space, and facilitating smooth data transfers. In the Linux ecosystem, the gzip utility shines as a powerful compression tool, allowing users to easily compress files and directories. This article delves into directory compression using the…
So what’s the default compression level?
The default compression level for gzip is 6. 1 = fastest and 9 = best compression
