How safe is it for me to stay on Debian 9?
I have a VM that is running Debian 9 and was EOL in 2020 and LTS ends June 30th, 2022.
How high risk is it to stay on Debian 9 for say another year? I was told this is very risky as there are no security updates.
Is there any reason you would not upgrade? Is this a production environment?
If it’s not a production server, and it has limited access (no outbound access), it’s risky but not unheard of to run an older OS with EOL.
Not advisable. It may not be high risk, but it for certain does not give you peace of mind. Are you worried about an in-place upgrade?
Start by backing up. Then read here: DebianUpgrade - Debian Wiki | or here.
Staying on Debian 9 is a security risk since it doesn’t get any updates after it’s EOL.
I went from 9 to 12 (Bookworm) and it’s SOOOOOOOOO much better. Unless you haven’t been doing backups etc there should be no reason to stay on 9. I would advise you go to 10 and then 11 but that’s just me, because every time I’ve tried to jump that much I’ve wound up doing a fresh install. Yes my luck sucks :wink:
Don’t do what I do, but I still run an internal-only VM running 32-bit RHEL5. Since this is a homelab server that is only available on my network, I don’t really care about it, but it’s definitely not a best practice.
My world-facing production servers are recent versions of FreeBSD or Ubuntu, and I keep those updated, for some hopefully-reasonable definition of “updated.”
I would agree for an internal server as well. Just lock it down with firewall rules (pfsense / opnsense)
Yeah, I should implement outbound rules to prevent any rogue programs from contacting the world, but there’s no incoming access to this server (other than SSH & HTTP from my network). I’ve never really gotten into outbound firewall rules. Tried it with Little Snitch on my Mac, and I find that they make life difficult, so I quit using them.
It is completely safe but there’s no incoming access to this server (other than SSH & HTTP from my network)
Sincerely, advising someone to stay or not to stay on a Distro without ongoing security patches is dependent on the use case scenario. If it is being utilized as a web server, there is absolutely no option than to upgrade to the latest supported version.
If it is used for a low risk utility, say, internal test machine, it can still be used if software and services running can be minimized.
I still run CentOS 5 (32-bit!) on an internal system. One of these days I should migrate its services to a newer distro, but for now it works fine. :smiling_face_with_sunglasses:
Yes, this is the same system I mentioned 3 years ago. lol
