Bubblejail installation
https://github.com/igo95862/bubblejail
Do you know how to install it to Zorin correctly? Because I have dome kind of phobia to break system since there is no exact step-by-step guide fom dev…
@krish
Please go through the README.md file, which is having installation steps, Here is the link:
I do
Manual Installation
If your distro does not have a package you can try to manually install with meson
But https://github.com/igo95862/bubblejail/blob/master/docs/distro_notes/ubuntu.md do not have any guide.
But building it is too hard for me. I am a little bit above newbie level…
@krish you can try temporarily disabling AppArmor and see if bubblejail starts working.
If it does, then AppArmor is probably blocking bwrap. You can then tweak the profile (maybe allow required capabilities like sys_admin) or check flatpak/ bwrap config.
I allow bwrap with sys_admin and mount for my system.
