Bash script syntax help
If I run this script off the desktop, I get a desktop notification of the IP I’m connected to:
#!/bin/bash
notify-send $(curl ifconfig.me)
But I can’t figure out how to include this other line to see if my expressvpn is connected (desktop notification):
expressvpn status
It just returns blank, as if the line was isn’t even present.
Also see: GitHub - sttz/expresso: expresso is a command line interface to control the ExpressVPN app · GitHub
Any ideas?
What if you add ECHO $<your_varible_for_output_here> expressvpn status
Also I’m not sure which Distro you are using but In Debian there’s a program “DocBook” that gives all your documentation a single point of access (a web page) and I downloaded “Advanced Bash-Scripting Guide: An in-depth exploration of the art of shell scripting” and it’s free to download and use. That might be a good thing to get too.
+1 to what @tmick says. Try this:
#!/bin/bash
notify-send "$(curl ifconfig.me)" "$(expressvpn status)"
