Arch Linux | How to repair yay
Small “repair” guide in case the package manager yay shows the following or a similar error:
error while loading shared libraries: libalpm.so.14: cannot open shared object file: No such file or directory
If yay shows such a message, nothing works anymore, yay refuses the service. This can happen in particular if an Arch Linux-based distribution has not been updated for a long time.
Unfortunately, uninstalling and reinstalling yay via Pacman does not help in this case.
We have no choice but to “rebuild” yay from the sources.
Step 1: Remove yay
sudo pacman -R yay
Step 2: Clone source packages
We change to a temporary directory, e.g. /tmp and download the source packages from yay:
git clone https://aur.archlinux.org/yay.git
Step 3: Compile source packages
After downloading, we change to the new directory yay and start the “build process”:
cd yay
makepkg -si
Now yay should work properly again.
Step 4: Error: Cannot find the debugedit binary
It is possible that the debugedit package is missing for compiling.
Then simply use
sudo pacman -S debugedit
and carry out step 3 again.
Thanks for sharing this. Making me miss Arch!
Great guide! Rebuilding yay from source is definitely the way to go when running into that libalpm.so.14 issue, especially after long periods without updates. The debugedit tip is also a lifesaver—good call, including that for anyone compiling. Clear steps and very helpful!
Thank you @devdev. i have tested the steps several times on different systems. always with success.
Thanks @toadie for sharing this! it might be very usefoul!
-r
