Analyzing the tcp files using golang. I wrote this standalone golang application. The worst part of the tcp files is that they are written using the linux io.utils and the file.io utils and those have not a good way of calling the format. This will give you what you actually need and you can use this with the network profiler
GitHub - codecreatede/go-network-devops-systemd: implementing the socket connection check in golang for routing interfaces to the systemd to generate and then analyze with the tcp analyzer GitHub - codecreatede/tcp-analyzer: golang tcp-analyzer container network proxies
Thank you all,
