hashicorp_terraform_initiator
A shell invoker to make your HCL hashicorp programming easy and to write the init files easy for any instance and to deploy them on the cluster integration. simply provide the instance name and the routing cluster and the deployment zone mode and it will make the hashicorp deployment variable declaration and the invokation file.
make any number of the hashicorp terraform instance either by directory providing the region, user and the interface or by providing the file with the network route. I integrated the C and releasing a new add on in C++ also for the same and you can invoke that on any instance provider
#! /usr/bin/bash
# Universitat Potsdam
# Author Gaurav Sablok
# date: 2024-1-24
# generating the terraform installation files
read -r -p "please provide the link region:" region
read -r -p "please provide the number of the networks ipinterface:" ipinterface
read -r -p "please provide the provider:" provider
if [[ ${interface} == "ipaddress" ]]; then
count=0
interfacelink=()
while [[ "${count}" -le "${ipinterface}" ]]; do
read -r -p "please provide the network interface:" interface
interfacelink+=("${interface}")
((count++))
done
echo "the provided interfaces are: ${interfacelink[*]}"
for i in ${interfacelink[*]}; do
echo "provider "${provider}" {
profile = "${i}"
region = "${region}"
done
elif [[ ${interface} = "file" ]]; then
read -r -p "please provide the file name for the interface:" filename
read -r -p "please provide the region for the instance creation:" region
if [[ -f ${filename} ]]; then
echo "the file is present"
interfacelink=()
for i in $(cat "${filename}" | cut -f 1 -d ","); do
interfacelink+=("${i}")
if [[ "${i}" == "" ]]; then
break
fi
done
fi
fi
profile = "${i}"
done
